small block header question #1130842
12/09/11 09:27 PM
12/09/11 09:27 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I was wondering if any of you guys had dyno'd a small block with a 4" stroker crank with Hedman Hustler's and TTI's new headers. Both with 1 7/8 primarys. See any difference in numbers? Do the tti's fit better then the Hedmans? And lastly does any one make a header with 2" primarys?
Re: small block header question [Re: 80arrow] #1130843
12/09/11 09:51 PM
12/09/11 09:51 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have the 1 7/8 Hedman Huslers on my small block Dart and have to say they are the easiest header to install that I have ever owned. Much easier than the 1 5/8-1 3/4 TTIs I have.
Hedman makes the Husler in 2".
Re: small block header question [Re: justinp61] #1130844
12/09/11 09:59 PM
12/09/11 09:59 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Hooker used to make a 2" primary header also...dont know if it still available..
HR-5322 ...
Tony
70 AARCuda Vitamin C
Re: small block header question [Re: 70AARcuda] #1130845
12/09/11 10:59 PM
12/09/11 10:59 PM
oregon
greendart408 Offline
oregon
I never had my car on the dyno with my tti's. I can tell you what my car gained at the track consistently. I have a 4in crank motor with w5 heads. I originally had 1 7/8s tti's on it and went mid 9.70s at 137+ consistently. Put my 1 7/8s hedman hustlers on it and run mid 9.60s at 138.50+ consistently now. My hedmans fit great.... hedman makes a 2in header also. Hedman hands down if you want to go fast imop. Btw this was with no other changes.
Re: small block header question [Re: greendart408] #1130846
12/09/11 11:54 PM
12/09/11 11:54 PM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
Headman will also build 1-7/8 to 2 inch steps I have a set of 1-3/4 to 1-7/8 steps on my dart.
Re: small block header question [Re: W2DODGE] #1130847
12/10/11 11:27 AM
12/10/11 11:27 AM
8
80arrow Offline OP
80arrow  Offline OP
Which would be better 1 7/8 to 2 or just straight 2 inch primaries. The motor is a 408 with Indy 360-1, roller cam, 9.0 to 1 comp. F1R procharger, meth inj., and a2a ic. shooting for about 950-1000 horse.
Re: small block header question [Re: 80arrow] #1130848
12/10/11 11:41 AM
12/10/11 11:41 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would thik a strait 2in.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
