QFT / Proform Carb Parts QC not impressive... 8^( #1130463
12/09/11 01:31 PM
12/09/11 01:31 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Just an FYI - I picked up a set of the Quick Fuel / Proform 4-emulsion hole "race" metering blocks along w/ one of the new aluminum Quick Fuel / Proform "950" 1.45" venturi x 1.75" throttle main bodies and figured I should pass on my observations.
Main body
1. Casting quality OK, although the finish machine work on the metering block surfaces is fairly rough and should definitely be used w/ a highly conformable gasket, rather than a harder (more durable) one that might not seal the irregularities as well.
2. Booster alignment / centering looks decent, but the actual machine work of the boosters is lacking, IMO. The taper from the top inside of the boosters isn't consistent from piece to piece and the insides of the boosters down to where the step for improved fuel shear is machined can be a bit "crusty." You can go onto Summit's web site and look at their nifty "360 View" pictures of the Proform 950 main body and QFT 6-950 (or is it 950-6?) which are the identical parts sold by both and actually see the same issue w/ their display models.
Metering blocks
3. These metering blocks are the ones that have the emulsion holes pre-drilled, although you can open them up if you choose and use screw-in bleeds. The as-delivered emulsion holes are supposed to be .028" on all holes from what I can find out (which isn't from Quick Fuel's Tech Support which neither replied to my voice mail nor responded to my requested e-mail more than a week ago), but when I gauged them there were random sizes of .024", .026" and .028" on both blocks. I've since set them all to .028".
4. Not sure what size the replaceable PVCR restrictions are supposed to be (see "lack of response from QFT" comment above), but I can tell you they're drilled about 3/4 of the way through w/ .059", then shrink down from there. Also, they're not drilled straight and opening them up all the way to .059" would start to broach the threaded area on the sides of two, maybe three of them. I've since taken new blank bleeds and drilled a set of new (straight) ones.
Keep in mind that these are the same parts that Quick Fuel uses in their Q-series carbs and Proform in their "race" series. I hope they do a better job of addressing all this "stuff" when they actually build carbs using their own parts than when they sell them to customers who might actually expect them to be machined properly.
Re: QFT / Proform Carb Parts QC not impressive... 8^( [Re: BradH] #1130464
12/09/11 01:34 PM
12/09/11 01:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why don't you send them back if you are not happy with them?
Re: QFT / Proform Carb Parts QC not impressive... 8^( [Re: BradH] #1130465
12/09/11 01:38 PM
12/09/11 01:38 PM
BradH Offline OP
BradH  Offline OP
I bought them specifically for future testing purposes and was already aware of potential issues from grumblings I'd seen posted on the web elsewhere. So, I was prepared to deal with this stuff and wasn't exactly surprised.
Other people may make the assumption that their stuff is "right"; consider this a Caveat Emptor for everyone else.
Re: QFT / Proform Carb Parts QC not impressive... 8^( [Re: BradH] #1130466
12/10/11 05:54 PM
12/10/11 05:54 PM
BradH Offline OP
BradH  Offline OP
Just a bump for the weekenders...
Re: QFT / Proform Carb Parts QC not impressive... 8^( [Re: BradH] #1130467
12/10/11 06:03 PM
12/10/11 06:03 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my QF carb was VERY nice right out of the box would buy another 1 without a second thought.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: QFT / Proform Carb Parts QC not impressive... 8^( [Re: dusturbd340W5] #1130468
12/10/11 07:16 PM
12/10/11 07:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
OK I got to ask ? If you knew they would not be right why did you buy them? and why did't you buy Parts from someone else ?
Re: QFT / Proform Carb Parts QC not impressive... 8^( [Re: VernMotor] #1130469
12/10/11 07:49 PM
12/10/11 07:49 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
I thought he did indicate why he bought them!
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: QFT / Proform Carb Parts QC not impressive... 8^( [Re: BradH] #1130470
12/10/11 09:53 PM
12/10/11 09:53 PM
AndyF Offline
AndyF  Offline
Sounds about par for the course. I've purchased low grade parts in the past just to see if I could make them work, but these days I try to buy the good stuff the first time.
Re: QFT / Proform Carb Parts QC not impressive... 8^( [Re: AndyF] #1130471
12/10/11 10:51 PM
12/10/11 10:51 PM
Mt.Vernon ,Ohio
VernMotor Offline
Mt.Vernon ,Ohio
Caveat emptor is Latin for "Let the buyer beware".
I had to go look that up LOL
Re: QFT / Proform Carb Parts QC not impressive... 8^( [Re: VernMotor] #1130472
12/10/11 11:32 PM
12/10/11 11:32 PM
Minot, ND
darndart Offline
darndart  Offline
Minot, ND
I've had a ProForm 950, a QuickFuel 1050, and now a QuickFuel Hot Rod Series carb, and I've got to say they all worked phenominal! Best working carbs I've ever owned!
73 Dart Sport 340, 410ci, Indy 360-2 230CNC.
72 Demon 340 4-speed
01 Ram Quad Cab
89 Mustang LX Boss 331,C4,HP76mm turbo, FAST EFI
86 Mustang GT 5.0 AOD
82 Capri RS 306, Fox Lake Stage 1 TW, N41, T5,etc.
