Turbo Question HELP needed!! #1130313
12/09/11 02:16 AM
12/09/11 02:16 AM
Ledbetter Kentucky
74dust Offline OP
74dust  Offline OP
Ledbetter Kentucky
I just acquired a Borg Warner gm-3 off a 6.5 diesel and was wondering if anyone had specs on those and would it be large enough for a 400 hp 318 single turbo set up? Thanks
Re: Turbo Question HELP needed!! [Re: 74dust] #1130314
12/09/11 02:38 AM
12/09/11 02:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont have any specs but a 6.5 is a fair bit bigger than
a 318 so by rights it should have enough in it to
scatter a 318 pretty easy..... just a guess... but
it would make a difference when it start to spool
Re: Turbo Question HELP needed!! [Re: 74dust] #1130315
12/09/11 12:16 PM
12/09/11 12:16 PM
Jacksonville Florida
elitecustombody Offline
Should be more than plenty for 400,as long as you have supporting mods,just don't expect an instant spool up,might have to grab a sandwich,lol. There should be casting numbers,try searching online for specs.
Re: Turbo Question HELP needed!! [Re: elitecustombody] #1130316
12/09/11 04:23 PM
12/09/11 04:23 PM
Ledbetter Kentucky
74dust Offline OP
74dust  Offline OP
Ledbetter Kentucky
The engine I have is already built to 400 hp I was wondering if this was large enuf to be a decent power adder or if I will need 2?
Re: Turbo Question HELP needed!! [Re: 74dust] #1130317
12/09/11 05:28 PM
12/09/11 05:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just 1.... try to find the map for that unit
Re: Turbo Question HELP needed!! [Re: 74dust] #1130318
12/09/11 09:44 PM
12/09/11 09:44 PM
Really depends on what you mean decent power, but I'd say it's large enough to gain couple hundred easy.I mess with Turbo Supras ,the little 3 liter can put down 700+ on 67mm turbo,but that's with high quality billet turbo,right supporting mods,good tuner that knows what he's doing to get all the power out of your combo.Dealing with turbo cars can get very expensive.Good set of cams,good flowing head with extensive head work,right exhaust manifold,wastegate,intake mani,t/b,lightened,ballanced, built bottom end with forged rods & pistons,billet dual or triple ballbearing turbo and you got over 40k under the hood Get a good fuel pump and turn up the boost.BTW, I'm assuming you built the motor with lower compression for boost. Otherwise it wouldn't be safe to run past 8 psi.
Re: Turbo Question HELP needed!! [Re: elitecustombody] #1130319
12/10/11 02:17 AM
12/10/11 02:17 AM
Ledbetter Kentucky
74dust Offline OP
74dust  Offline OP
Ledbetter Kentucky
The Block has been shaved heads are porter all the way intake has been ported to match heads running 9 to 1 compression forged pistons stock rods and crank cam is a comp cam made for boost or nitrous with a long power band form 3000 to 6500 rpm plan on running a carb box with a Holley 650!! will this turbo be to small? or does anyone have any suggestions?
