Page 12 of 14 1 2 10 11 12 13 14
Re: Subframe connectors, which way shoul [Re: dart70la] #1121
11/24/04 07:17 PM
11/24/04 07:17 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
rapom Very nice job. Im gonna have to cut mine out and redo them. I wasnt happy with how they were done the first tim.
Re: Subframe connectors, which way should we [Re: rapom] #1122
11/24/04 08:10 PM
11/24/04 08:10 PM
S.E. Michigan
ZIPPY Online content OP
ZIPPY  Online Content OP
S.E. Michigan
Great job rapom. Looks just like mine did before the outriggers and roll bar.
Rich H.
Esse Quam Videri
Re: Subframe connectors, which way should we [Re: ZIPPY] #1123
11/24/04 08:44 PM
11/24/04 08:44 PM
S.E. Michigan
S.E. Michigan
More pics to add since the old ones are all dead...
This is the outrigger + main hoop installation
Rich H.
Esse Quam Videri
Re: Subframe connectors, which way should we [Re: ZIPPY] #1124
11/24/04 08:49 PM
11/24/04 08:49 PM
S.E. Michigan
S.E. Michigan
This is the full roll bar.
Kicker bars are welded to the frame tie.
Side bars are welded to front outriggers (2x3 stub welded between the rocker and the frame rail)
The only pieces that are sitting on plates are the two rear bars, in the trunk...everything else is part of the structure.
The eventual need for a roll bar was a real deciding factor when doing the frame ties this way....it paid off to plan ahead.
Rich H.
Esse Quam Videri
Re: Subframe connectors, which way should we [Re: ZIPPY] #1125
11/24/04 10:25 PM
11/24/04 10:25 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Thanks for the compliments guys. Molloy, I'm no chassis guy but that sounds like a good idea. Zippy, I think the pics Todd DesMarais sent me were of your the install of the connectors on your car. I wasn't sure though.
Your cage install looks awesome. You won't have to worry about the car not being stiff enough when you have future torque upgrades.
Re: Subframe connectors, which way should we [Re: rapom] #1126
11/25/04 04:38 PM
11/25/04 04:38 PM
Clarkston,MI
Todd_DesMarais Offline
super street
super street
Clarkston,MI
Holly Crow, IT'S STILL ALIVE !!!!!
Good job John, I'm a bit supprised that you welded the floor on the bottom also. and yes the pics I sent you were of the "Zippety Doo Dah's" car sorry Rich, had to say it.
Todd
aduC' 47 IIeredevleB 66 383 etilletaS 66 DTC 0053 MAR 50 "ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
Re: Subframe connectors, which way should we [Re: Todd_DesMarais] #1127
11/25/04 05:31 PM
11/25/04 05:31 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I also thought it was a little overkill but I welded both sides because I wanted it to look cleaner. I also mini tubbed and moved leaf springs into the frame rails last winter. This fall I replaced some of the trunk floor and cleaned off the sounddeadener on the inside quarters. I wanted to sandblast and paint the undercarrage but it now seems a little to cold for putting on the Zero Rust since it has to be above 50 to use it. My next big jobs this winter are to replace the lower rear quarters and fill in the trim holes down the side of the car. This pic is of some 325/50/15 drag radials that fit in the tubs nicely now. The car will be sitting a lot lower than the pic shows though. Did you do any work to your 66 yet.
Re: Subframe connectors, which way should we [Re: rapom] #1128
11/26/04 11:16 PM
11/26/04 11:16 PM
Clarkston,MI
super street
super street
Clarkston,MI
"it has to be above 50 to use it." three words, Radiant Tube Heater I love the lines of a coronet 'specially with meats in the back !
As for work on mine, well.....I did get it to the house this summer and have removed the hacked on drivers rocker panel. it was repaired from an accident and obviously done by someone who either didn't care, or had no idea of how to do a quality job. they "removed" some of the damaged rocker with a chisel and put one from another car over it by using a hammer and brazing rod. so I picked up a parts car for the rocker and a-pillar door post (piece where the vin tag is riveted) since mine has a slight inward bend to it.
I'll ship a few pics .
Todd
Re: Subframe connectors, which way should we [Re: Todd_DesMarais] #1129
11/27/04 10:44 AM
11/27/04 10:44 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I really didn't want to paint in my garage if I didn't have to. With all the fumes and everything plus I would have to cover my other cars up and I have a pooch that sleeps in the garage over night. But I might do it. I look forward to seeing your pics.
Re: Subframe connectors, which way should we [Re: rapom] #1130
04/11/05 11:56 PM
04/11/05 11:56 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Re: Subframe connectors, which way should we [Re: Dos Snails] #1131
04/12/05 04:47 PM
04/12/05 04:47 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Good idea, this thread has to much good info to let go.
Re: Subframe connectors, which way should we [Re: rapom] #1132
04/13/05 02:27 AM
04/13/05 02:27 AM
hmmm interesting i did mine completly different i used 3x3 cut the flour pan, and on the rear of the original frame its L shaped at the flour pan then i welded in 1/4 x 3 x 8 inch plates to the original rear frame and rear conector.then in the front on the scrossover the flour pans on the front are cut out so i boxed the tranny crossmember witch looks flimsy anyways and added gussets to the inside of it to make it more riggid then i welded the front of the connector to it.After that i welded in a 3x3 in the back across the frame at the shock crossmember and cut the old thin cheep shock crossmember out and added gussets to the frame as well,then i went back in side and welded 2x3 from the rear of the frame conector across over the tranny hump and back to the other frame conector and added gessets so now the the tranny crossmember (that i boxed in) and the frame connectors are all one piece in both directions .then i added 1/8 x4 to the inside of the frame ralls from the trans crossmember all the way's to the radiator crossmember and trimed it to match the frame the car is solid as a rock Next i'm going to start drilling holes every place i can to loose weight.
Re: Subframe connectors, which way should we #1133
04/13/05 11:11 PM
04/13/05 11:11 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Damn, Motorcar you building a tank?
Re: Subframe connectors, which way should we [Re: Dos Snails] #1134
04/14/05 12:42 PM
04/14/05 12:42 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I guess I'll participate & keeps this one going also. There is another thread going right now on frame connectors also. The is what I did with mine. I have done mine a totally different way then everyone else. It was alot of extra work. But I am going for that sleeper look (if that is possible with a HEMI car!!!!) I want the all stock look. I cut off the rocker panels of my 70' Challenger & hid the 2"x3" tubing inside the body. I tied it into the transmission cross member body support at the front stitch welded along the entire body & into the side of the rear frame rails at the rear. I obtained an original set of factory E-body boxed in spring perches from an original HEMI parts car. Once I installed these the only way to tell the car has been frame connected is to look into the small square hole from underneath that is there to mount the rear leaf spring mounts. It came out awesome but was alot of work. The car is still on the rotisserie as of now completely stripped & there is no body flex at all.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Subframe connectors, which way should we [Re: 6PKRTSE] #1135
04/14/05 04:53 PM
04/14/05 04:53 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Wow, that is a lot of work!
Re: Subframe connectors, which way should we [Re: rapom] #1136
04/15/05 12:16 PM
04/15/05 12:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yes it was. But it is probably going to be a 10 second all steel,full interior,all stock appearing street car. To modified to run pure stock. I will probably do the same thing to my Charger when I finally restore it someday. But for now I just made some quick welded 1-1/2"x2" connectors like everyone else has when I put the HEMI in the Charger. They definately make a difference. Frame connectors should of been factory for big block cars.
Re: Subframe connectors, which way should we [Re: ZIPPY] #1137
09/08/05 03:06 PM
09/08/05 03:06 PM
Central NE
mopurist Offline
mopurist  Offline
Central NE
Old thread but GREAT information. Unfortunately the pictures appear to be long gone.
I am working on my '69 RR and am at the point where I have to decide what type of SFC to use. After reading the thread, I am leaning towards the 2x3 homemade units extending into the rear subframes.
Although I think many of the post adequately describe the process, pictures are worth a 1000 words, blah, blah, blah...
Anyone care to repost the pictures of theirs? Please!
Thanks.
Re: Subframe connectors, which way should we [Re: mopurist] #1138
09/08/05 03:12 PM
09/08/05 03:12 PM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Check out the ones from US CARTOOL designed to be welded directly to your floor. They look great.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: Subframe connectors, which way should we [Re: 70Coronet500Vert] #1139
09/08/05 06:05 PM
09/08/05 06:05 PM
Central NE
mopurist Offline
mopurist  Offline
Central NE
I did check out uscartool.com, but I couldn't find any information on connectors for a 69 b-body (only e-bodies and 71-2 b-body).
They do seem nice, and if they are available for a 69, I would definitely give them serious consideration, even though they are nearly 10x the cost of a length of 2x3. The almost-factory look and no need to worry about hacking the floorpan may be worth it.
Re: Subframe connectors, which way should we [Re: mopurist] #1140
09/08/05 06:37 PM
09/08/05 06:37 PM
Brunswick, Jawgia
Snailpower Offline
Infinitely Fast Snail
Snailpower  Offline
Brunswick, Jawgia
I just got a set of them at the Nationals and I must say I am impressed. I have not had a chance to install them yet, but I can't wait. Funny thing is, I just finished some 2x2 connectors on my wagon, which made a big difference in the car WITHOUT tying into the floor. The Coronet is much faster and will see dragstrip duty, so the US Car and Tool frame connectors is the way to go for the turbo car. Besides, John at US Car and Tool is great to deal with!
70 Coronet- turbocharged 360/518/3.73 SG
