funky driveline shutter UPDATE
#112922
08/31/08 01:04 PM
08/31/08 01:04 PM
Posts: 1,277 USA IN
E85-408
USA IN
Last night I was driving around and noticed a funny shutter off the line. Not sure what it was, it feels like it's trying to shifter into second or third but not all the way. I then noticed it doing the same thing when I was in second gear and once in first gear but never in third. When it happens I will let off the throttle and it stops. If I hit the gas some while it's doing it..it hits hard the quits. If I get on it alittle and run through the gears it doesn't do it, only when I'm kinda putting around. I've noticed around and under 2000rpms it does it alot but no where near all the time.
The car is my 72 dodge demon which is my daily driver. The motor is a 340 and the trans was built by me 2 years ago and has never given me any problems. It has a SMR 3k conveter, SMR manual reverse valve body, lower first gear, ray bands and clutches, the multi spring kit and built servo. It's a non lockup up 904.
I have a console shift and have checked and rechecked the linkage adjustment with the help from my gf. I'm at a complete lost on what it is. Any help would really be appreciated. Thanks.
Re: funky driveline shutter
[Re: E85-408]
#112923
08/31/08 09:36 PM
08/31/08 09:36 PM
Posts: 1,277 USA IN
E85-408
USA IN
