94 Caravan Transmission Failure #1129197
12/07/11 01:33 AM
12/07/11 01:33 AM
Oahu, Hawaii
P
ParadiseCuda Offline OP
P
Oahu, Hawaii
I have a 94 grand caravan and the trans has decided to not shift anymore. It is the 4 speed automatic behind a 3.0L. It feels like it is starting out in second and stays there. No up shifts or down shifts. It recently had the passenger side half shaft replaced. Trans fluid level is good. Where do I start to diagnose this issue?
Re: 94 Caravan Transmission Failure [Re: ParadiseCuda] #1129198
12/07/11 01:53 AM
12/07/11 01:53 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Have it scanned...
Re: 94 Caravan Transmission Failure [Re: ParadiseCuda] #1129199
12/07/11 01:57 AM
12/07/11 01:57 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Those early auto trannies can be a horror show. LOOK in some of the CL posts .... LOTS of them are there "trans NR".
Chrysler didn't get the prob sorted out uNtil the late 02 model year.
Re: 94 Caravan Transmission Failure [Re: ParadiseCuda] #1129200
12/07/11 11:25 AM
12/07/11 11:25 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
sounds like it is in the "limp" mode and may be a module or electronic issue. My '91 would do this and sometimes just disconnecting the battery would get it to (??) reset or something Have it scanned like suggested. (btw it too felt like it was in 2nd gear and would stay there and never shift just like you described......the "limp mode"
MikeR
Re: 94 Caravan Transmission Failure [Re: A12] #1129201
12/07/11 12:58 PM
12/07/11 12:58 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
"limp mode"
This is what I was thinking. When our 2000 did this it was just the speed sensor. There is a high and low speed snsor that tells it to shift. Replaced both and no problems since. 4 years gone by now.
I have mechanical Aptitude.
I can screw up anything.
Re: 94 Caravan Transmission Failure [Re: bboogieart] #1129202
12/07/11 02:12 PM
12/07/11 02:12 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
"limp mode"
Speed sensor sounds like this may be the cause.....and not that this would be an issue or a way of it going into the limp mode by the OP but I could get it to go into the limp mode by spinning the (front) wheels in slippery conditions like SNOW when I first started the car and the trans hadn't shifted yet. If it stayed in 2nd gear/limp mode then I'd have to shut the engine off and reset it, not spin the wheels until it shifted on its own.
MikeR
Re: 94 Caravan Transmission Failure [Re: A12] #1129203
12/08/11 12:29 AM
12/08/11 12:29 AM
Oahu, Hawaii
P
P
Oahu, Hawaii
Thanks for all the replies. I will try to reset it and then get it to a garage to run a scan. I sure hope it is speed sensors. I need to get a few more thousand miles out of it, I just put on some new tires which doubled the value of the van.
Thanks for the help.
Re: 94 Caravan Transmission Failure [Re: ParadiseCuda] #1129204
12/11/11 12:45 AM
12/11/11 12:45 AM
Oahu, Hawaii
P
P
Oahu, Hawaii
Where are the transmission speed sensors located on this 94 FWD Grand Caravan 4 speed automatic sitting beside a 3.0L. I took a look and I saw a few items that could be the sensors but I am not sure. Any help would be greatly appreciated.
Re: 94 Caravan Transmission Failure [Re: ParadiseCuda] #1129205
12/11/11 01:14 AM
12/11/11 01:14 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Found this, text said it was 91, might be the same...
Re: 94 Caravan Transmission Failure [Re: 1_WILD_RT] #1129206
12/11/11 12:22 PM
12/11/11 12:22 PM
Oahu, Hawaii
P
P
Oahu, Hawaii
Wild RT, that looks like the one. Once the sun comes up I will see if it matches up. Thank you.
Re: 94 Caravan Transmission Failure [Re: ParadiseCuda] #1129207
12/11/11 12:29 PM
12/11/11 12:29 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
95% of the time the input sensor is the problem,replace it with a OEM sensor,they are/were around $20 dealer cost,takes about ten minutes to change.You would be surprised how many transmission rebuilds were done/sold by shady transmission shops and dealers because of a $20 part..
Re: 94 Caravan Transmission Failure [Re: 62maxwgn] #1129208
12/11/11 06:50 PM
12/11/11 06:50 PM
Oahu, Hawaii
P
P
Oahu, Hawaii
Wild_RT the picture you provided was spot on, thank you. I guess my web search skills need some improvement.
62maxwgn my plan was to replace both sensors but do the output sensor first since my speedodmeter was still working.
Thanks to all.
Re: 94 Caravan Transmission Failure [Re: ParadiseCuda] #1129209
12/11/11 06:54 PM
12/11/11 06:54 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
When looking for a picture rather than text I change to the images tag on Google... It makes finding a useful picture much easier..
Glad I could help...
Re: 94 Caravan Transmission Failure [Re: 1_WILD_RT] #1129210
12/12/11 01:12 AM
12/12/11 01:12 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Also make certain your battery is good.
The 604 in my 96 sebring acted up alot and would go into limp mode on occasion. Even though the charging system was up to snuff, the battery would start he car...most of the time.
Changed the battery, shifting problems went away.
Re: 94 Caravan Transmission Failure Follow-up [Re: ParadiseCuda] #1129211
12/18/11 01:44 AM
12/18/11 01:44 AM
Oahu, Hawaii
P
P
Oahu, Hawaii
Well, replaced both speed sensors and still no luck. I am going to inspect the wires on the input speed sensor a little closer tomorrow. I am hoping to find a broken wire by the sensor.
There never was a check engine light but I reset the computer by disconnecting the battery for a good 15 minutes. It only shifts one time and then stays in second. What a bummer.
Re: 94 Caravan Transmission Failure Follow-up [Re: ParadiseCuda] #1129212
12/18/11 01:49 AM
12/18/11 01:49 AM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
What were the codes on the scan? Guessing is expensive!
Re: 94 Caravan Transmission Failure Follow-up [Re: ParadiseCuda] #1129213
12/18/11 02:54 AM
12/18/11 02:54 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Get it to a TRANSMISSION shop and have them scan it, including a CVT (clutch volume test). They can shift fine but if the computer sees that it takes too much fluid to apply the clutches it assumes clutch wear and goes into limp in mode. Most regular scanners or code readers don't read this.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 94 Caravan Transmission Failure Follow-up [Re: Evil Spirit] #1129214
12/18/11 11:16 AM
12/18/11 11:16 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
A bad TCM will also cause the same problem,get it scanned.Went through the same problem with my 93 T/C.
Re: 94 Caravan Transmission Failure Follow-up [Re: 62maxwgn] #1129215
12/18/11 12:14 PM
12/18/11 12:14 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Scanners? ...TCM's ??....
Oh - how I remember the dayz of a simple and straight-forward 727 or 904 !
Re: 94 Caravan Transmission Failure Follow-up [Re: dOrk !] #1129216
12/18/11 01:54 PM
12/18/11 01:54 PM
Oahu, Hawaii
P
P
Oahu, Hawaii
Well, then off to find a scanner. I didn't have it scanned yet. I will this week if no broken wires are found today.
