best way to clean an oil pan? #112894
08/31/08 12:17 PM
08/31/08 12:17 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I just picked one up from the junkyard and need to clean both the inside and outside for my new motor. What's the best thing to use? Remember, I'm in CA so I probably can't get a lot of the solvents that are stronger than B-12 Chemtool or Brakleen.
Re: best way to clean an oil pan? [Re: sharpie] #112895
08/31/08 12:20 PM
08/31/08 12:20 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
scraper, wire wheel and brakeclean. I did this one awhile ago and never used it. Rusting a little from humidity.
Re: best way to clean an oil pan? [Re: snuggles] #112896
08/31/08 12:40 PM
08/31/08 12:40 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Drown it in dishsoap and let it soak in and then wash it with hot water and a scrub brush. Repeat until clean.
Re: best way to clean an oil pan? [Re: sharpie] #112897
08/31/08 12:41 PM
08/31/08 12:41 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Lots of ways to go. I'd likely use Oven-Cleaner, Degreaser, soak in water/ laundry-detergent, scrub with bristle-brush and steel-wool scouring pads, etc. You can remove old paint with "Aircraft" Paint Remover.
An engine-rebuild shop could either hot-tank (if still available) or use their more environmentally sensitive alternative cleaning systems.
Another choice might be Media (Sand) blasting followed by washing in soapy-water to remove any residual grit, ... lots of choices.
Re: best way to clean an oil pan? [Re: D_C] #112898
08/31/08 01:13 PM
08/31/08 01:13 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Thanks for the answers, guys. I'll probably go with the old dishsoap-soak and brakekleen/wire brush scrub
Re: best way to clean an oil pan? [Re: sharpie] #112899
08/31/08 01:16 PM
08/31/08 01:16 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Use lot's of hot hot water to rinse and if it has baffles be sure they are clean underneath.
Re: best way to clean an oil pan? [Re: sharpie] #112900
08/31/08 01:26 PM
08/31/08 01:26 PM
1. Use a paint scraper or and coarse steel wool and remove everything caked on.
2. Take it to a self service car wash and and remove anything that will wash off.
3. Spray it down with easy-off oven cleaner.
4. Let it sit for 1 hr.
5. When the wife isn't looking!! put it in the dishwasher with lots of dish washer detergent on pots and pans cycle.
Repeat steps 3-5 until it is clean.
After you are done, cycle the dishwasher empty to clean out any residue you may have left.
You may have to remove the upper basket.
This procedure is fine for anything that will fit in the dishwasher.
I have used it for heads, bell housing, carb, engine sheet metal, and do not forget the 727 cleaning.
Re: best way to clean an oil pan? #112901
08/31/08 01:29 PM
08/31/08 01:29 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I'm installing a dishwasher in the garage for this next to the oven.
Re: best way to clean an oil pan? #112902
08/31/08 01:30 PM
08/31/08 01:30 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Easy off oven cleaner,first, then wash off with high pressure soapy water, then when wife is gone, put it in the dish washer.
If this method fails, then take it to an auto shop and have it vatted
Re: best way to clean an oil pan? [Re: Mopar-Al] #112903
08/31/08 02:14 PM
08/31/08 02:14 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I took the brakleen and a cloth to it yesterday and most of the inside looks like it'll rinse. I think I should be fine with a good spray and wash and then brakleen to finish it off.
Re: best way to clean an oil pan? [Re: sharpie] #112904
08/31/08 09:10 PM
08/31/08 09:10 PM
Friendsville, TN
Reverend_Ron Offline
super street
super street
Friendsville, TN
This method will only cost about $44.72....
Give the wife cash to go shopping; two twenties are always nice. The $4.72 will be apparent shortly. As she leaves the drive way, throw the oil pan in the dishwasher - add 2 tbsps of GOJO in the pre-wash reservoir and 5.5 onces of solvent in the main wash reservoir and select Pots & Pans Wash Cycle. Crack open a beer and get on Moparts.com to ask a few more questions. After beer three and some great advice from mopar-brothers world wide - your oil pan will be ready for install. Smartly throw in all the dishes lying in the sink and head on back out to the garage.... she'll never be none the wiser!!!!
68 Roadrunner, 383,4-spd 71 Superbee, Citron Yella, 383,slapstick 71 Charger 500, Autumn Bronze, 383,4-spd, A/C 72 Imperial, 2-dr hdtp 74 Charger SE, 440-auto, sunroof 84 Crew Cab Dually, 440-auto 01 Quad Cab Dually, HO Cummins;6-spd 08 H-D, Softail Custom 08 Challenger, 6.1 Hemi
Re: best way to clean an oil pan? [Re: Reverend_Ron] #112905
08/31/08 09:22 PM
08/31/08 09:22 PM
North Las Vegas
chewy Offline
chewy  Offline
North Las Vegas
Thats what I was going to suggest.
My wife caught me washing car parts in the dishwasher once. It wasnt pretty.
Re: best way to clean an oil pan? [Re: Reverend_Ron] #112906
09/01/08 10:38 AM
09/01/08 10:38 AM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
What kind of beer are you buying for $4.72?
Re: best way to clean an oil pan? [Re: pyp1000] #112907
09/01/08 11:04 AM
09/01/08 11:04 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Sounds like the kind that will require $1.00 worth of advil the next day.
Re: best way to clean an oil pan? [Re: Dart 340] #112908
09/01/08 09:51 PM
09/01/08 09:51 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I use mineral spirits in my parts cleaner. I assume they still allow mineral sprits in CA.
Easy on the hands and will clean off the oil in a flash..
Re: best way to clean an oil pan? [Re: chewy] #112909
09/01/08 11:46 PM
09/01/08 11:46 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I am banned from the dishwasher because of this. Threw in a set of valve covers and was drinking beer out in the garage. Too many beers and I forgot all about the valve covers. The next day wife opened up the dishwasher to get a coffee cup or something. Morning after many beers and 3 hours sleep waking up to a pissed off wife is not good. Needless to say she got a new dishwasher.
Re: best way to clean an oil pan? [Re: Posest] #112910
09/02/08 12:01 AM
09/02/08 12:01 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
EZ-Off heavy duty oven cleaner here too, along with a stiff scrubbing brush.
Ride eternal, shiny and chrome
Re: best way to clean an oil pan? [Re: snuggles] #112911
09/02/08 12:04 AM
09/02/08 12:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Having Acces to one of these...Priceless...
