66 BELVEDERE 5 SPEED CONVERSION #1128909
12/06/11 04:54 PM
12/06/11 04:54 PM
pa
greg383 Offline OP
greg383  Offline OP
pa
Would like to convert my 66 belevedere 383 to a 5 speed.Im just in research and development mode right now.wonder if anyone has done this and where would be a good place to get the right stuff.
Re: 66 BELVEDERE 5 SPEED CONVERSION [Re: greg383] #1128910
12/06/11 04:58 PM
12/06/11 04:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you afraid of cutting up the car to get the correct driveline angle and for the shifter to come thru the floor ?
Re: 66 BELVEDERE 5 SPEED CONVERSION [Re: JohnRR] #1128911
12/06/11 08:53 PM
12/06/11 08:53 PM
anytown
440dodge440 Offline
440dodge440  Offline
anytown
I did it with a 64 Dodge 440 with a 66 and up K frame (engine moved towards back from stock). I used a lot of the information in a thread here by 446acuda for pilot bearing, etc...
http://www.moparts.org/Tech/Archive/clutch/25.html
The scattershield is a Lakewood with tapped blocks for the Tremec bolt pattern. The bearing retainer is turned down slightly to fit the Lakewood. The center of the crossmember was cut out and replaced with structural tubing welded in to clear the transmission. There are a few flanges on the transmission that were ground off- nothing of any significance. The bolt-in transmission cross member is home-made. All clutch linkage is factory.
Re: 66 BELVEDERE 5 SPEED CONVERSION [Re: greg383] #1128912
12/06/11 09:00 PM
12/06/11 09:00 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would cut out all the B.S.and get a Passon 5-speed and all your factory stuff will work
Gus
64 Plymouth Savoy
Dana 60
Re: 66 BELVEDERE 5 SPEED CONVERSION [Re: 440dodge440] #1128913
12/06/11 09:09 PM
12/06/11 09:09 PM
anytown
440dodge440 Offline
440dodge440  Offline
anytown
more
Re: 66 BELVEDERE 5 SPEED CONVERSION [Re: 440dodge440] #1128914
12/06/11 09:10 PM
12/06/11 09:10 PM
anytown
440dodge440 Offline
440dodge440  Offline
anytown
Re: 66 BELVEDERE 5 SPEED CONVERSION [Re: 440dodge440] #1128915
12/06/11 09:12 PM
12/06/11 09:12 PM
anytown
440dodge440 Offline
440dodge440  Offline
anytown
Re: 66 BELVEDERE 5 SPEED CONVERSION [Re: 440dodge440] #1128916
12/06/11 09:13 PM
12/06/11 09:13 PM
anytown
440dodge440 Offline
440dodge440  Offline
anytown
Re: 66 BELVEDERE 5 SPEED CONVERSION [Re: greg383] #1128917
12/06/11 09:29 PM
12/06/11 09:29 PM
AndyF Online content
AndyF  Online Content
There are a couple of kits available to do it or you can roll your own. I put a Doug Nash in my '65 Coronet more than 20 years ago. I wouldn't do a Doug Nash these days, but back then that was all that was available.
You didn't provide enough information for anyone to really help you though. Not sure if this is a street car or a race car, not sure how much power you have, what size your budget is, etc.
