Firm Feel steering boxes??? Whats the deal??? #1128454
12/05/11 10:07 PM
12/05/11 10:07 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I am installing the complete Hotchkis suspension system on an E Body.
I was wondering what to do regarding steering and Im looking at the Firm Feel Hydraulic steering boxes.
How good are they and will they work for what Im doing? Which stage to get? 1, 2 or 3?
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128455
12/05/11 10:42 PM
12/05/11 10:42 PM
IN
ahy Offline
ahy  Offline
IN
They are very carefully rebuilt boxes with reduced assist for more "feel". Careful rebuilding reduces slop and seems to help them last longer.
I run level II and like it. Most folks like level II or level III. A firm feel box would be a great part of a handling package.
Besides the box itself, other factors influencing "feel" are alignment settings, tire size and steering wheel. More caster increases feel and effort as do bigger tires and a smaller wheel.
Re: Firm Feel steering boxes??? Whats the deal??? [Re: ahy] #1128456
12/05/11 11:32 PM
12/05/11 11:32 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
firm feel box 2 or 3 - most pro touring guys go for 3
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128457
12/06/11 12:00 AM
12/06/11 12:00 AM
albemarle, NC
dusterbd13 Offline
dusterbd13  Offline
albemarle, NC
e had a 3 in my car for years, and regularly beat the ever living snot out of the thing on the autocross, street, etc. were talking hot lapping, over driving, etc. just hammer it.
before the ffi 3 box, i had a fresh diplomat cop car box in it. the stage 3 was a dramatoc upgrade.
that being said, i feel it os still over assisted, but just by a couple of hairs. thats with a lot of positive caster, and 255/40/17 that are pretty sticky.
only about 10 degrees of on center dead spot at athe wheel, but a lot of that (probably 4-6 degrees)comes from the rebuilt mopar coupler. one of these days,m its getting switched to a u-joint to take that slop out as well.
id say spend the money and enjoy.
michael
Michael Crawford CSP 1970 plymouth Duster back under construction: http://www.pro-touring.com/showthread.ph...ouring-makeover 1964 el camino beater shop truck 96403-project-drivabeater-2-0-64-el-camino-this-time
Re: Firm Feel steering boxes??? Whats the deal??? [Re: dusterbd13] #1128458
12/06/11 05:24 AM
12/06/11 05:24 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I have a level 2 in my 69 Coronet R/T and love it, and would probably try a level 3 next time, takes a ton of the "float" out of the factory power steering system.
Darren
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128459
12/06/11 06:39 AM
12/06/11 06:39 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
If you're going TVS use stage 3 and the quick ratio arms. At least the pitman, depending on your headder. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Firm Feel steering boxes??? Whats the deal??? [Re: HUSTLESTUFF] #1128460
12/06/11 09:29 AM
12/06/11 09:29 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
I use the 3. like it
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128461
12/06/11 09:37 AM
12/06/11 09:37 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I use the stage 2 and like it. I think stage 3 would be too stiff for me with a tough wheel in my challenger. Maybe with a bigger wheel stage 3 would be OK?
Combined with there upper control arms, reinforced lower control arms and welded up K memember, my car is worlds better than any challenger I've ever drove. I welded up the K and the lower control arms, well worth it.
My car is just a driver, but boy does it handle good for 40 year old car thanks to Firm Feel.
Re: Firm Feel steering boxes??? Whats the deal??? [Re: Challenger 1] #1128462
12/06/11 11:26 AM
12/06/11 11:26 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128463
12/06/11 12:13 PM
12/06/11 12:13 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I have a TVS on my Challenger with FF stage 3 and the long arms. Had to adjust the steering box since the inner tie rod hit the torsion bar.
The Stage3 box is a little stiff with a small steering wheel. I have a rim blow and don't think I would want any thing smaller.
Re: Firm Feel steering boxes??? Whats the deal??? [Re: RTSE4ME] #1128464
12/06/11 12:18 PM
12/06/11 12:18 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I have driven several cars with FF Stage III boxes and would be puttng one in any power steering car I own, I wouldn't buy anything else.
Re: Firm Feel steering boxes??? Whats the deal??? [Re: ScottSmith_Harms] #1128465
12/06/11 01:11 PM
12/06/11 01:11 PM
O
OLD318 Offline
OLD318  Offline
O
I had mine rebuilt stage 1.... It is a huge improvement over the
turn the wheel with your pinky slop of the original...
However, having done that... I wish I had gone to stage 2..
I recommend a minimum of Stage 2.
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128466
12/06/11 01:39 PM
12/06/11 01:39 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Domingo- FF Stage 3 here, with Hotchkis tubular upper a arms, 1 1/4" front sway, 1" torsion bars, and clicker shocks- MAJOR inprovment from stock.
Re: Firm Feel steering boxes??? Whats the deal??? [Re: Kirby] #1128467
12/06/11 05:57 PM
12/06/11 05:57 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
So if using a Rim Blow or a Std Wheel would the firm feel stage 3 be the ticket? Or should I just stick with 2?
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128468
12/06/11 06:07 PM
12/06/11 06:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I have used the StageIII with standard wheels and tough wheels. Neither was a problem for me.
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128469
12/06/11 06:12 PM
12/06/11 06:12 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
I've been using FFI boxes for years with total satisfaction. The other guys (Ohio) - not so good.
Also, don't forget:
Zero-buck firm feel
Rick
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128470
12/06/11 06:15 PM
12/06/11 06:15 PM
Marlboro, NY, USA
Marlboro, NY, USA
...also...don't forget FFI's new needle-bearing idler and ball bearing lower pitman "bolt-on" setup (takes out K-flex).
Rick
Re: Firm Feel steering boxes??? Whats the deal??? [Re: Rick_Ehrenberg] #1128471
12/06/11 06:41 PM
12/06/11 06:41 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
and I have a Fast Ratio arm on it as well-
Re: Firm Feel steering boxes??? Whats the deal??? [Re: Rick_Ehrenberg] #1128472
12/06/11 06:42 PM
12/06/11 06:42 PM
Port Saint Lucie, FL
ChallengerGary Offline
Also, don't forget:
Zero-buck firm feel
Rick
SWEEET!!! Thanks for sharing!
Re: Firm Feel steering boxes??? Whats the deal??? [Re: domingo] #1128473
12/06/11 07:55 PM
12/06/11 07:55 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
My dad runs a Stage III in his RR, he and I both love it feels like a modern car. It almost makes me want to give up the flaming river manual box I have in my Dart.
1972 Road Runner
1988 Shelby CSX-T
