Warning! Replacement sm. blk. timing covers/ long
#1128330
12/05/11 07:47 PM
12/05/11 07:47 PM
Posts: 1,708 S. Il. U.S.A.
5spdcuda
S. Il. U.S.A.
Recently I decided to replace my timing cover gasket on the 'Cuda in order to fix a small water leak. I thought that since these aluminum covers have been known to corrode I would install a new timing cover at the same time. I ordered a new timing cover [ part # P5249930AB ] from Mancini Racing. This is the MP part not the cheaper Mancini house brand. Let me say right now that this is NOT a anti-Mancini rant, they have agreed to take it back and refund my credit charge account, so unless they renege I have no quarrel with them. Now as to the problem. When I received it I noticed that it was considerably heavier than an OEM piece, but other than some sharp edges it looked OK. I did notice there wasn't anything to indicate the country of origin, just two letters and the words "timing cover, replace original equipment". I waited until after I installed the front main seal and painted it before pulling my old OEM [ made in Canada ] cover off the engine. After setting the new gasket in place I tried putting the new cover on. NO WAY was it seating in the oil pan. After cleaning the gasket sealer off the new cover I made a very thorough inspection of the new cover relative to the OEM piece. When you placed them back to back the problem became obvious. The new cover is nearly 1/8 in. wider at the semi-circular section just under the "ears". If you weigh 400 lbs or use a really big bar you might be able to force it on, but you will probably warp the oil pan doing it. If the engine is on a stand with the oil pan off it will certainly bolt to the front of the engine, but you will play h&*%$ getting the front of the pan on. This has been really annoying, first I paid $20.00 extra to get the MP cover instead of the house brand thinking I would get OEM quality and I've wasted a good seal and gasket set. To say nothing of the time involved. At least my original cover is sound and reusable. I wish I had the skills to post pictures, but I hope I've explained it adequately. I am not a professional engine builder, but I have been doing this for nearly half a century [ yeah, I am old ] so I am not exactly a novice either, or that I haven't ever done this kind of work before. I can only imagine what someone who is inexperienced would try to do in this situation. Get a bigger hammer, maybe? An 1/8 in. may not sound like much and this area is supposed to be a snug fit since it seals the pan to the timing cover, but certainly not this tight.
Re: Warning! Replacement sm. blk. timing covers/ long
[Re: Locomotion]
#1128332
12/05/11 09:14 PM
12/05/11 09:14 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
they must have been changed in the last 2 years or maybe just a bad 1. I got a MP piece 2 years ago and it fit great. But it wouldn't surprise me at all.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1128333
12/05/11 09:53 PM
12/05/11 09:53 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I guess I'm too cheap for that, I just use used stuff for something like that. I have a couple timing covers if you need one. Even a magnum one that I was going to use on my new 408 because it has ears to bolt a diaper to, but I would need to make (or buy) a new water pump plate and engine plate to mount it, so I just kept the old one and will make a belly pan.
