273 hi=po plug wire grommets? for 66 engine #1128302
12/05/11 07:08 PM
12/05/11 07:08 PM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
I came upon a 66 273 hi-po motor that the previous owner had sunk a ton of money into making it look exactly like the original, so I need to continue his work. The motor has the original restored valve covers, but has no plug wires. It appears the wires are held in place on top of the valve covers on the stands with some type of grommet? Anyone know where/if I can obtain the grommets, or whatever they are. I can't find a pict to show what these gidgets look like.
Re: 273 hi=po plug wire grommets? for 66 engine [Re: Mike H] #1128303
12/05/11 07:25 PM
12/05/11 07:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: 273 hi=po plug wire grommets? for 66 engine [Re: Mike H] #1128304
12/05/11 08:30 PM
12/05/11 08:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
all 273's of that time frame used them, just about any Mopar resto supply place can get them.
Don't be the exception.
Re: 273 hi=po plug wire grommets? for 66 engine [Re: gtx6970] #1128305
12/06/11 01:34 PM
12/06/11 01:34 PM
dogdays Offline
dogdays  Offline
How do they work with 8.5mm wires?
R.
