Wiper Motor interchange
#1127792
12/05/11 12:43 AM
12/05/11 12:43 AM
Posts: 3,344 Central TX
roe
Central TX
I have a 71 Satellite with 2 speed wipers and need a new wiper motor. What other vehicles can I pull one from because I cant find one anywhere. None of the parts stores, rockauto, ebay, no one has any. So Im curious as to if I can pull one from any vehicles other than other early 70's cars? Any help would be greatly appreciated.
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: Wiper Motor interchange
[Re: roe]
#1127793
12/05/11 02:06 AM
12/05/11 02:06 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
69-71 c , 70-71 e, 71 b The plug on top of the motor will have 1 brass terminal indicating how it parks.
NS1AAR
[Re: ns1aar]
#1127794
12/05/11 03:56 AM
12/05/11 03:56 AM
roe
Central TX
So I have found all the ones in the following links on ebay, and none of them will fit right? And the only difference between the motors is where the wipers park, or do they have a different swing radius? If there is one that I could get to work and function well, I'd be fine with that. http://www.ebay.com/itm/1969-1970-Mopar-...=item45fef140echttp://www.ebay.com/itm/2-SPEED-WIPER-MO...=item588f0c53e1What about this one? Its says 71-74 b bodies in the heading but only says 73-74 in the vehicle compatability section. http://www.ebay.com/itm/2-Speed-Wiper-Mo...=item27c0db6639http://www.ebay.com/itm/NOS-MoPar-68-73-...=item4cf310f76chttp://www.ebay.com/itm/WIPER-MOTOR-2-SP...=item588f1e0fe6Found this one ( http://www.ebay.com/itm/NOS-MOPAR-1969-7...=item35b5e64079 ), right part# and everything but they want $275 crazy http://www.ebay.com/itm/MOPAR-2-SPEED-WI...=item19c4237038Again, Im not looking for a "correct" part, just one that will work with my application, wouldn't mind if the parking was a little off, or it didn't quite swing the arms as far as normal, if that makes sense. Dont wanna dump that kind of coin on a doggone wiper motor. thanks roe
[Re: DANA60]
#1127796
12/05/11 10:50 AM
12/05/11 10:50 AM
roe
Central TX
Looks good to me, you have a PM coming your way. I was also wondering about switching to a 3 speed motor. What else is it necessary to change? Linkage, electrical connectors, wiper control switch? Can you just plug in a 3 speed motor and keep everything else hooked up like a 2 speed, and just have it serve as a two speed since theres only 2 speeds on the control switch?
Thanks roe
