Re: Need a SB head gasket ".036"
[Re: Dartcuda]
#1127687
12/04/11 11:48 PM
12/04/11 11:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
why not go with a felpro #1008 at .039 , surely .003 can't make that much difference
Thats what I would do... Cometic gaskets arent cheap
[Re: Dartcuda]
#1127689
12/05/11 12:01 AM
12/05/11 12:01 AM
Posts: 892 USA
krw71ragtop
USA
I re-read my notes and I need .035" . My flat top pistons are .003" in the hole and all I'm finding is .039" gaskets, which puts me at .042". I'm looking for good quench this time around. My old pistons had a 17cc dish. Am I being too picky ? Thanks
[Re: krw71ragtop]
#1127691
12/05/11 12:26 AM
12/05/11 12:26 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Did you check all 8 cylinders and record what EACH of them was in the hole? Not often will they be +/- .001"
Did you true deck the block?
[Re: autoxcuda]
#1127692
12/05/11 01:05 AM
12/05/11 01:05 AM
Posts: 892 USA
krw71ragtop
USA
Yes the block was decked and I did check all cylinders. But thanks for the reminder. Now if I could just find a sport hood for my 2011 Ram as fast as you guys helped answer my question ! At a reasonable price ! I guess I am too picky.
[Re: Grizzly]
#1127695
12/06/11 12:27 AM
12/06/11 12:27 AM
Posts: 892 USA
krw71ragtop
USA
Oh, it's out there K. The twin to yours with dual scoops just hasn't been rear-ended yet!
But, there is snow on the roads now so it shouldn't be too much longer.
That's what I'm hoping ! The sooner the better. Can't beleive how people forget how to drive when it snows.
[Re: Alikazam]
#1127696
12/06/11 12:39 AM
12/06/11 12:39 AM
Posts: 892 USA
krw71ragtop
USA
I'd definitely go Cometic anyway. I'm on my 3rd reuse of my set, well worth the $$$ spent. Just my $.02
I've never used them before. I'm going to need a complete tear down gasket set besides the head gaskets. I will check the cometics out. Usually get my parts from Mancini. Thanks for your
[Re: krw71ragtop]
#1127697
12/06/11 12:45 AM
12/06/11 12:45 AM
MR_P_BODY
When using Cometic gasket the block and head surfaces need to be milled a certain way ... just so you know
