69 B-body rear defrost? #1127495
12/04/11 03:11 PM
12/04/11 03:11 PM
southern Idaho
moparcyco Offline OP
southern Idaho
This one is a two part question.
1.Can this be installed fairly easily on a car that was not so equipped?Does anyone have some pics of how it is installed?This is my first B-body and have never seen the setup before.It gets cold where I am and while the car is apart would be a worthwhile upgrade.
2.Are the parts readily available?Or do you have to score a setup from a donor car?Is there anything different on the dash?I have the ralley (spelling?)dash.As always thanks for your help guys
Re: 69 B-body rear defrost? [Re: moparcyco] #1127496
12/04/11 03:22 PM
12/04/11 03:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Pretty easy install. They were common to have dealer installed and sold out of the accessories catalog.
I put one in my 68 Barracuda Notchback when I lived in Iowa. They don't work very well. Nothing close to modern heated grid rear defrosters.
All it does is de-fog your rear window. Just the interior fog on the glass. So when a couple of people get into a car and thier breathing and body heat caused a differential in the cold outside the car, fog is formed on the inside of the glass.
They blow air from the inside of the car back on the window sucked from the rear speaker grille. So you can't have two rear speakers unless you buy this offset adapter that pgclassics sells for $159. BTW It's not heated air. Some have a coil inside that people think is a heater, but it is a resistor for the two speed blower motor. And has extremely little effect on the air passing by it.
No new parts available except NOS and the adapter brack from PG Clasics. So get a complete unit.
Re: 69 B-body rear defrost? [Re: autoxcuda] #1127497
12/04/11 05:35 PM
12/04/11 05:35 PM
southern Idaho
southern Idaho
Well sounds like maybe not such a good uprade.will the heater take care of it quickly?I've never really driven my challenger in the colder weather.This car will get driven much more just don't want any saftey issues.Is there possibly something better out there?Thanks
Re: 69 B-body rear defrost? [Re: moparcyco] #1127498
12/04/11 05:49 PM
12/04/11 05:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
in all honesty, it wouldn't be worth the hassle. they straight up don't work except to blow air on the window. buddy had one in his RoadRunner back in the day. this was back in Upstate NY. the thing did nothing but make a bunch of noise.
Re: 69 B-body rear defrost? [Re: moparcyco] #1127499
12/05/11 12:09 PM
12/05/11 12:09 PM
pa.
dan9 Offline
dan9  Offline
pa.
I have one in my 69 rr. I agree with the other posts. It's not heated air. Mine also has a separate switch in the dash. That may be the hardest part to find.
Re: 69 B-body rear defrost? [Re: dan9] #1127500
12/05/11 12:29 PM
12/05/11 12:29 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
How does yours work in getter fog off the inside of your rear window?
Re: 69 B-body rear defrost? [Re: autoxcuda] #1127501
12/05/11 01:14 PM
12/05/11 01:14 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
pulls heated air from the inside the passenger compartment - if it doesn't get warm air , it doesn't blow warm air
Re: 69 B-body rear defrost? [Re: autoxcuda] #1127502
12/05/11 01:34 PM
12/05/11 01:34 PM
pa.
dan9 Offline
dan9  Offline
pa.
Mine is pretty useless. I think the window gets cleared mostly from the heat/defrost instead of the rear window unit. It was in mine so i left it but i wouldn't go to the trouble of adding one in my opinion.
