727 storage question #1126989
12/04/11 01:19 AM
12/04/11 01:19 AM
North Chicagoland
N
newbee69 Offline OP
newbee69  Offline OP
N
North Chicagoland
Hey all,
Is it necessary to "turn over" a tranny that will sit for awhile?
Like turning over a motor or spinning the yoke on an axle to keep lubed?
I didnt think it was, as I figured the enemy of trannys is primarily heat, but it was suggested to me to do it for the seals.
So....if yes, then how the heck would you "turn it"? just spin the shafts? with or without converter?
Yeah I know...strange question, but when I heard that, It got me thinking.
Thanks for the help.
Re: 727 storage question [Re: newbee69] #1126990
12/04/11 01:31 AM
12/04/11 01:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Actually moisture is the enemy... all I do is use the
plugs to seal it up... I pick up a trans plug kit some
years back for the 727/904 .... P/N P4120280
Re: 727 storage question [Re: newbee69] #1126991
12/04/11 01:59 AM
12/04/11 01:59 AM
several years ago I rebuilt a 904 then let it sit ouside for 2 years w no covering or dipstick (dont ask ) then I dropped the pan (in the summer) and it had no water so I went ahead & ran it & it performed flawlessly. I do coat/drown everything w trany fluid inside when I rebuild one. best plan for one (or any part) is to store it in a somewhat low humidity environment where the temp stays high & doesn't fluctuate/drop below the condensation level (dew point?). Sealing something up with moisture inside traps that moisture inside
Re: 727 storage question [Re: RapidRobert] #1126992
12/04/11 11:45 AM
12/04/11 11:45 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had one sit for 8 years in the garage, no plugs or anything other than a dipstick. All I did was put a new front seal in it and it still worked flawlessly when I put it back on the road.
68 Barracuda Formula S 340
Re: 727 storage question [Re: Bad340fish] #1126993
12/04/11 12:08 PM
12/04/11 12:08 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I am in ND where winter temps reach -30 or even colder in the winter and have had rebuilt 727's sit several years in an unheated pole garage and they suffered no ill effects. They have a lot of lubricant applied during assembly. Take the pans off before installation and have yet to find any condensation in one.
Re: 727 storage question [Re: MoparforLife] #1126994
12/04/11 02:10 PM
12/04/11 02:10 PM
North Chicagoland
N
newbee69 Offline OP
newbee69  Offline OP
N
North Chicagoland
Thanks gentlemen.
That is what I thought, but the suggestion about "turning over" got me thinking.
The 727 is full of fluid and wrapped in big garbage bags inside a dry garage, so shouldnt have any problems with moisture or cold anyways.
Shouldnt be sitting for that long. Has been for just a couple months and should be ready to drop in by summer.
Thanks again for the "piece of mind"....
Re: 727 storage question [Re: newbee69] #1126995
12/11/11 08:29 AM
12/11/11 08:29 AM
5thAve Offline
5thAve  Offline
For just a few months and inside it won't be a problem.
Re: 727 storage question [Re: 5thAve] #1126996
12/11/11 11:14 AM
12/11/11 11:14 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
x 99 ... and even if you store it outside .. not a prob. Just as long as you have it covered up and no rain or snow can get inside.
