Re: New stereo in 1997 Caravan-NE1 do it lately??
[Re: BFASTER]
#1126935
12/04/11 12:09 AM
12/04/11 12:09 AM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
Have you tried Crutchfield?
Old, tired, and sometimes broke down. Me, not my car...
[Re: BFASTER]
#1126936
12/04/11 12:15 AM
12/04/11 12:15 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I am assuming this is a van with the Infinity system. The blue wire that is marked in most instructions as the power antenna is in reality the 12V feed to the speakers (they are amplified). Hook this to 12V and you will have your bass and audio from all the speakers. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1126937
12/04/11 01:01 AM
12/04/11 01:01 AM
denfireguy
Colorado
Clarification: the blue wire should be hooked to switched 12V coming from the radio. The conversion harnesses label the blue wire as for the power antenna. Since most vans do not have power antennas, the installer assumes it is not needed. Then the audio sounds like 1970 era 4 track. Craig
[Re: hornetnut]
#1126939
12/04/11 04:53 AM
12/04/11 04:53 AM
Posts: 624 Modesto CA
BFASTER
Modesto CA
Wow....I should have come hear earlier. This new info should do the trick and I'll be rockin again THANK YOU ALL FOR THE HELP!
1969 Dodge Super Bee Hardtop
2007 Nissan Altima 3.5SE
