Re: Pushrod clearance in Indy EZ1's
[Re: Stanton]
#1126878
12/03/11 11:03 PM
12/03/11 11:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You can do them on the mill but I cant say its worth all the set up time for each one... I did this on my B-1 M/Cs ... I used a 1/2" end mill but I had to take alot of material out
[Re: Stanton]
#1126880
12/03/11 11:41 PM
12/03/11 11:41 PM
Posts: 314 Manitoba, Canada
Big Wedge
Manitoba, Canada
Yep, did the same on mine. I only had a couple that were touching. It was still well worth the effort.
Garth
[Re: 68 HEMI GTS]
#1126883
12/04/11 06:54 PM
12/04/11 06:54 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
people want to build custom engines but dont want to do the custom work that goes with it...
On the contrary! I expect someone manufacturing custom, high performance heads to do their homework so that when I run a relatively mild cam and valvetrain setup it should work without having to touch it. If I were running a .750 lift cam and 1.6 rockers I'd expect to have to do some fitting.
[Re: Stanton]
#1126884
12/05/11 07:45 PM
12/05/11 07:45 PM
Posts: 1,170 Westbury, NY
bumps440
super gas
super gas
Westbury, NY
I agree with you for the most part. with a name like EZ and using mild parts It should almost be a bolt on. I am doing a set of CNC victor max wedge port head with 1.7 rockers and very high lift. there is soo much material I have to remove it is not at all funny had them on a mill to remove a good part of it, may have to just touch up with carbide bits when its near enough to do another pre assembly.
