Re: Axle Shims
[Re: old yeller]
#1126856
12/03/11 08:52 PM
12/03/11 08:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a 63 chrysler with the 741 carrier(open)i want to put a posi in that rear end housing but from what i,m told i need to add axle shims when your going from a open rear end to a posi...mancini does not sell those shims..any old fart heads know what thickness shims i need....my chrysler books say i need them but they don,t say how thick or a part #(these axles have the big nut that hold them in) thanks in advance
I cant answer your question but that big nut at the drum is what holds the drum on(with a key way and key)
Re: Axle Shims
[Re: MR_P_BODY]
#1126857
12/03/11 09:14 PM
12/03/11 09:14 PM
Posts: 728 mi usa
old yeller
mi usa
Well crap(u were one of the old fart heads i thought i could count on..lol..j/k)If i have to i,m just going to weld up the spider gears...poor mans way of haveing a posi...i know chirp,chirp,there goes a axle...then i,ll just have to put a dana in it..
Re: Axle Shims
[Re: old_racer]
#1126859
12/03/11 10:12 PM
12/03/11 10:12 PM
Posts: 728 mi usa
old yeller
mi usa
Hi, I've done this before, the axles were shorter on a sureqrip back then, but I did it by taking a the flanges of a later bolt in type axle and cutting the center out of them so all you have left is the ring with the bolt holes in it. they're about 1/8 to 3/16in thick, that's about how much shorter the axles were, then you use one on each side and then play around with the stock thin shims that come with a open rear to get the end play you need, around .008 total. I've got some stock thin shims if you need some more to play with. either that way or you have to cut the axles off. it will also move your brake drums out a like amount which shouldn't hurt as long as you don't have a rust ridge where the shoes don't run. Russ
You sir, r my new hero,i see your from WI,if ur close to east troy WI,Gus's drivein every august has their 7 sec 8 sec street 10 wide tire event(i,m invited every year)Dinner is on me!
Re: Axle Shims
[Re: old_racer]
#1126860
12/04/11 05:28 PM
12/04/11 05:28 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Why mess around with shims, just cut/grind 1/8" off the splined end of each axle shaft...I've done it numerous times. (remember to chamfer the ends a little) You may need some more of the original shims to adjust the end play or you may need to remove some.
Re: Axle Shims
[Re: old_racer]
#1126861
12/04/11 08:26 PM
12/04/11 08:26 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"I've done this before, the axles were shorter on a sureqrip back then " Old racer,what is the cutoff year for the shorter axles on a suregrip? I have a 68 Charger with a "one legger" 742 and have a 742 suregrip unit I was getting ready to install. I thought it was a simple pull old/install new new job. Thanks Mike
Re: Axle Shims
[Re: old_racer]
#1126863
12/04/11 08:56 PM
12/04/11 08:56 PM
John_Kunkel
Rio Linda, CA
Actually, '64 is the first year that the axles were the same length....'63 and earlier have shorter axles with SG.
