Re: SRT8 Oil pressure monitor
[Re: BEINGmeISaCRIME]
#1126801
12/05/11 12:06 PM
12/05/11 12:06 PM
Posts: 329 Orange Park, FL
MRHWS
Orange Park, FL
Not pointing fingers, but who services this car? It takes many months for them to get that low unchecked. The wheel sensor warning comes on about 25 psi(not the safest and not good for the tires, but ok at city speed), that's 10 psi below the required for a 245x45x20 tire. It only takes 5 seconds to check on the dash display. Now the oil light. As said prior, 0w40 synthetic every 3,000 miles. It's good for 5,000, but the "Dealers Service Required" message will display for 10 seconds at every start-up after the 3,000 mile computer reset. Unless there is a computer or sensor glitch, I would say wrong oil or lack of timely service or both. Unknown driving habits and engine mileage might also play into this. How much oil did you add? The 6.1 holds 8 quarts. I don't know for sure, but I don't think the light would come on if less than 1 quart low.
1973 Charger SE
1974 Charger Rallye 440 Aztec
2008 Charger SRT8
Re: SRT8 Oil pressure monitor-update
#1126803
12/10/11 03:21 AM
12/10/11 03:21 AM
Posts: 2,587 missouri, USA
moparmojo
missouri, USA
Ok, Im embarrassed to admit this, but in the interest of full disclosure.... I finally figured out what is going on with the car. As I said previously I was concerned with why the oil monitor screen was on in the dash and here is what I determined. The car kicked on the tire pressure indicator/warning when one of the tires got low. So after giving her some instructions and things to check she drove the car home. The next day I drove the car to see if the indicator would return and it did. So I added air to the offending tire at the local gas station. However, I left and the indicator was still on. I guess those little pumps dont put out that much ari in the cold. I park the car and go work on other projects. Unknown to me, the wife was playing with the different screens on the car to learn more about it and apparently had stopped on the oil pressure monitor screen. Fast forward to the next day, I finally track down my fancy tire gauge and pull out the air hose. I go and properly air up each tire to the correct PSI. I take for a test drive and the Tire PSI indicator/warning is gone. However, at the same time it the oil monitor screen appeared to "pop up" on me. ---Like I said it appeared to pop up. In actualality, it was merely in the background while the tire pressure psi indicator was on top of it. So this whole time I have been worried about the dang thing being on and it was as simple and hitting a coupld dang buttons. I feel silly, but I guess it gave me more of an opportunity to learn about the car and find out what it does. So everything was normal. Thanks for the help anyway..
