How many RPM's can you twist a stock 440 ? #1126719
12/03/11 02:20 PM
12/03/11 02:20 PM
Woodbridge,CA
NAS Backyard Offline OP
Woodbridge,CA
I have a .040 over stock (pistons) 440 with a mild cam, 727 /Gear Vendors/3:23 that I regularly pound on. My trans doesn't like to shift until around 6000 RPM's at WOT and I think it's a little late. I've adjusted the kick down and it shifts great under regular driving conditions, but wants to whined a little too tight for my comfort zone. The engine is balanced and was built be a reputable builder. Should I be worried?
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: How many RPM's can you twist a stock 440 ? [Re: NAS Backyard] #1126720
12/03/11 02:32 PM
12/03/11 02:32 PM
salem, oregon. usa
E
elmor Offline
elmor  Offline
E
salem, oregon. usa
I had a similar set up for my 67 440. .040 over, stock bottom end, MP 280 - .474 cam, with 3.91 rear. Used to twist it to 6300 rpms on a regular basis. Still runs great, but I wouldn't twist it any more than that.
Re: How many RPM's can you twist a stock 440 ? [Re: NAS Backyard] #1126721
12/03/11 03:26 PM
12/03/11 03:26 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
That's kind of a vague question.
The rpm range is dictated by the cam/intake/carb/heads/exhaust, the mass of the reciprocating lower end.... and so on.......
Reliability???? What max rpm with the heavy slugs a factory 440 used???? That's the real question. Probably not much over 6k.
You didn't mention the cam other than "mild". The package as a whole is probably overrunning the cams design. It's probably doing a "nose-over" deal where it's shifting past its peak.
Re: How many RPM's can you twist a stock 440 ? [Re: NAS Backyard] #1126722
12/03/11 03:45 PM
12/03/11 03:45 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Sounds like it's just right. If you shift it manually will it shift at a lower RPM if you want to shift sooner? 6000 is Nothing to worry about.
Re: How many RPM's can you twist a stock 440 ? [Re: NAS Backyard] #1126723
12/03/11 04:04 PM
12/03/11 04:04 PM
No & & if the preferred shift point is lower than 6K I'd change the governor weights to ch that then adj the kickdown seperately to where you want it to be & not use it to move the WOT shift points
Re: How many RPM's can you twist a stock 440 ? [Re: NAS Backyard] #1126724
12/03/11 04:11 PM
12/03/11 04:11 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
6000 to 6300 for a non stroked motor....I used to shift around 5500 as it wasn't doing much after that to justify waiting for the next shift...shift at different times and see which one gets You there quickest..I over rev'd a stroker motor and snapped the cam in half and disintegrated the #7 piston...thus destroying the #7 cylinder...
Re: How many RPM's can you twist a stock 440 ? [Re: NAS Backyard] #1126725
12/03/11 04:17 PM
12/03/11 04:17 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Depends on the TACH too.
I drove the same 440 powered car for 9 years, raced it regularly for 9 years, knew it like the back of my hand.
Shifted consistently exactly the same thousands of times. I never look at my tach while racing, and since my buddies were getting annoyed I bought an Autometer Sport Comp recall tach.
It would consistently pull 6400 rpm on the tach every time. Once every 50 runs or so.... it would read 7100 rpm. Then it would go back to 6400 rpms again and again.
It was weird.
We tossed the engine in my buddy's car years later. It had a Sun Super Tach II, which must be a much more powerful tach. He wound the engine over 8000 rpm!!!!!!!
I always wondered how his previous engine, which seemed mundane, was pulling 6500+ rpm!
I had a tic-toc-tac that would allow me to CRUISE at 5500 rpm with a similar engine, no idea what was wrong with that one!!!!
I almost wonder if some tachs are set for 6 bangers, the rpm I have seen.
Good stout 440s I have had were just over 6000rpm when I shifted, if the tachs were fairly accurate.
CrAzYMoPaRGuY
Re: How many RPM's can you twist a stock 440 ? [Re: NAS Backyard] #1126726
12/03/11 04:24 PM
12/03/11 04:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
REALLY depends on the quality of the build
pistons, rods, bearings, torque conv, flexplate,driveshaft, etc etc etc
IMO with cast pistons and stock rods on a regular basis??? I wouldn't !!!
Re: How many RPM's can you twist a stock 440 ? [Re: RapidRobert] #1126727
12/03/11 04:44 PM
12/03/11 04:44 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
probably good advice
Re: How many RPM's can you twist a stock 440 ? [Re: Dean_Kuzluzski] #1126728
12/03/11 05:05 PM
12/03/11 05:05 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Depending if it's a bone stock rebuild with a "warmer" cam thrown in, you have to take in account the balancing also (might free up a few hundred more USEABLE rpm up top). If the heads
have not been "touched", 6000rpm is the norm (Magnum based motor), anymore rpm is bonus!! But it comes at a price, a motor is only as good as the builder, so beware. Parts meant for strong performance in the low and midrange portions of the tach do not produce power in the far RIGHT side of the dial! And the
REVERSE is also true (midrange - top end cams produce little to zero low end power).
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: How many RPM's can you twist a stock 440 ? [Re: HYPER8oSoNic] #1126729
12/03/11 05:21 PM
12/03/11 05:21 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Run it up, note tach level when it blows up, back off 100-200 RPM...
How much it will wind and where it covers ground best are quite different.
If the cam isn't crazy I bet it would like something less than 5500.
Re: How many RPM's can you twist a stock 440 ? [Re: HYPER8oSoNic] #1126730
12/03/11 05:30 PM
12/03/11 05:30 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
WARMER ? ... so what oven-temp is that ?
And THIS from a who is something-funny and on his car all-the-time ...
Re: How many RPM's can you twist a stock 440 ? [Re: dOoC] #1126731
12/03/11 05:54 PM
12/03/11 05:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
6000 won't hurt an is about the limit of RPM with stock valve springs and lifters. I really don't know why you want to twit it that far. You are running way out of the peak power band.
Re: How many RPM's can you twist a stock 440 ? [Re: MoparforLife] #1126732
12/03/11 06:20 PM
12/03/11 06:20 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Thats somewhat of an unknown--all he says is "Mild Cam", Maybe his mild isn;t what someone else would say is mild.
Re: How many RPM's can you twist a stock 440 ? [Re: dOoC] #1126733
12/03/11 06:28 PM
12/03/11 06:28 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
For street use I ussually prefer 280 to 290 degrees advertised!!!
Is that warm enough??!!LOL!
Re: How many RPM's can you twist a stock 440 ? [Re: Pacnorthcuda] #1126734
12/03/11 06:57 PM
12/03/11 06:57 PM
Upper Midwest
Upper Midwest
Most so called 'mild' cams are done well before 6000. Even a lot of the not so mild cams have their power band peak below 6000.
Personally I prefer keeping the RPM as low as possible using a cam that produces in the 5500 to 6000 range. There is no question that you can run and run well with that type of cam and the engine will live a long and useful life.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: How many RPM's can you twist a stock 440 ? [Re: NAS Backyard] #1126735
12/03/11 07:07 PM
12/03/11 07:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Adjusting the Throttle valve(kickdown)Linkage doesn't do anything to the WOT shift point .'
Did you change the gov. weights to get that hi A WOT ? Stock they don't shift nearly that high , usually about 4800 or so ...
Re: How many RPM's can you twist a stock 440 ? [Re: NAS Backyard] #1126736
12/03/11 07:18 PM
12/03/11 07:18 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Let up off the gas when you wnat it to shift and it will.
Just a slight amount is all you need.
I have mechanical Aptitude.
I can screw up anything.
Re: How many RPM's can you twist a stock 440 ? [Re: bboogieart] #1126737
12/03/11 09:18 PM
12/03/11 09:18 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Chasis Dyno showed mine stopped pulling at 4850. Leveled off I guess. Warmed up. 415 RWHP.
Re: How many RPM's can you twist a stock 440 ? [Re: DennisH ] #1126738
12/03/11 10:17 PM
12/03/11 10:17 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Your build is probably peaking at about 5500 tops. Any RPM's over that is a waste.
I don't like taking a stock low end over 6000
The factory race manuals from the 70's that I wish I could find says 6500 max on a big block.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
