How many RPM's can you twist a stock 440 ?
#1126719
12/03/11 02:20 PM
12/03/11 02:20 PM
Posts: 5,449 Woodbridge,CA
NAS Backyard
Woodbridge,CA
I have a .040 over stock (pistons) 440 with a mild cam, 727 /Gear Vendors/3:23 that I regularly pound on. My trans doesn't like to shift until around 6000 RPM's at WOT and I think it's a little late. I've adjusted the kick down and it shifts great under regular driving conditions, but wants to whined a little too tight for my comfort zone. The engine is balanced and was built be a reputable builder. Should I be worried?
1970 Challenger Ragtop 426 4 speed
1961 Olds 88 2 dr Sedan 394 4 speed GVOD
1968 Pontiac Firebird 428 4 speed
2000 Ford F-150
2002 HD Roadking
1961 Licence Plate collection
1995 Buick Roadmaster
www.nogreenautolaws.com
Re: How many RPM's can you twist a stock 440 ?
[Re: NAS Backyard]
#1126721
12/03/11 03:26 PM
12/03/11 03:26 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
That's kind of a vague question.
The rpm range is dictated by the cam/intake/carb/heads/exhaust, the mass of the reciprocating lower end.... and so on.......
Reliability???? What max rpm with the heavy slugs a factory 440 used???? That's the real question. Probably not much over 6k.
You didn't mention the cam other than "mild". The package as a whole is probably overrunning the cams design. It's probably doing a "nose-over" deal where it's shifting past its peak.
[Re: NAS Backyard]
#1126725
12/03/11 04:17 PM
12/03/11 04:17 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Depends on the TACH too. I drove the same 440 powered car for 9 years, raced it regularly for 9 years, knew it like the back of my hand. Shifted consistently exactly the same thousands of times. I never look at my tach while racing, and since my buddies were getting annoyed I bought an Autometer Sport Comp recall tach. It would consistently pull 6400 rpm on the tach every time. Once every 50 runs or so.... it would read 7100 rpm. Then it would go back to 6400 rpms again and again. It was weird. We tossed the engine in my buddy's car years later. It had a Sun Super Tach II, which must be a much more powerful tach. He wound the engine over 8000 rpm!!!!!!! I always wondered how his previous engine, which seemed mundane, was pulling 6500+ rpm! I had a tic-toc-tac that would allow me to CRUISE at 5500 rpm with a similar engine, no idea what was wrong with that one!!!! I almost wonder if some tachs are set for 6 bangers, the rpm I have seen. Good stout 440s I have had were just over 6000rpm when I shifted, if the tachs were fairly accurate.
CrAzYMoPaRGuY
[Re: RapidRobert]
#1126727
12/03/11 04:44 PM
12/03/11 04:44 PM
Posts: 3,916 usa
lewtot184
usa
No & & if the preferred shift point is lower than 6K I'd change the governor weights to ch that then adj the kickdown seperately to where you want it to be & not use it to move the WOT shift points
probably good advice
[Re: HYPER8oSoNic]
#1126729
12/03/11 05:21 PM
12/03/11 05:21 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Run it up, note tach level when it blows up, back off 100-200 RPM... How much it will wind and where it covers ground best are quite different. If the cam isn't crazy I bet it would like something less than 5500.
[Re: HYPER8oSoNic]
#1126730
12/03/11 05:30 PM
12/03/11 05:30 PM
Posts: 30,430 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
with a "warmer" cam thrown in,
WARMER ? ... so what oven-temp is that ?
And THIS from a who is something-funny and on his car all-the-time ...
[Re: MoparforLife]
#1126732
12/03/11 06:20 PM
12/03/11 06:20 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
You are running way out of the peak power band.
Thats somewhat of an unknown--all he says is "Mild Cam", Maybe his mild isn;t what someone else would say is mild.
[Re: BeEtLeJuIcE !]
#1126733
12/03/11 06:28 PM
12/03/11 06:28 PM
Posts: 541 chatham, Ilinois
fox
super street
super street
chatham, Ilinois
For street use I ussually prefer 280 to 290 degrees advertised!!! Is that warm enough??!!LOL!
[Re: NAS Backyard]
#1126735
12/03/11 07:07 PM
12/03/11 07:07 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
Adjusting the Throttle valve(kickdown)Linkage doesn't do anything to the WOT shift point .'
Did you change the gov. weights to get that hi A WOT ? Stock they don't shift nearly that high , usually about 4800 or so ...
[Re: DennisH ]
#1126738
12/03/11 10:17 PM
12/03/11 10:17 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Your build is probably peaking at about 5500 tops. Any RPM's over that is a waste. I don't like taking a stock low end over 6000 The factory race manuals from the 70's that I wish I could find says 6500 max on a big block.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
