Scrub path length calculation? #1126177
12/02/11 04:01 PM
12/02/11 04:01 PM
New York
polyspheric Offline OP
New York
I've gotten a few questions about this, and noticed some commentary regarding "how large should this be?" (in addition to where it stops & starts).
Some very large numbers have been reported with no shock & awe.
In general, the scrub should be smaller than you would think, meaning some of those big numbers are really danger signals - the geometry isn't what you want. If you can't find another way, reducing the scrub length is a good direction to go.
All you need to predict what the minimum scrub should be is:
1. set the valve-side lever to mid-lift, yatta yatta
2. what's the effective length of the long lever (shaft center to roller axle or pad radius)
3. what's the net valve lift?
Let "S" = the minimum scrub length
Let "R" = rocker's long lever effective length
Let "L" = net valve lift
The formula is:
S=R-(R^2-(L/2)^2)^.5
Example 1:
R (lever) = 1.75", L (lift) = .600"
S=1.75-(1.75^2-(.600/2)^2)^.5
S=1.75-(3.0625-(.09)^.5
S=1.75-1.724
S=.026"
Example 2:
R (lever) = 1.50", L (lift) = .700"
S=1.50-(1.50^2-(.700/2)^2)^.5
S=1.50-(2.25-.1225)^.5
S=1.50-1.459
S=.041"
As you can see, scrub figures like .080" show something isn't working...
You can also calculate the rocker angle at zero lift and full lift (which will be the same with mid-lift, duh!).
The total arc (1/2 up, 1/2 down) is:
2×arcsin(L/2R)
Example 1 (R (lever) = 1.75", L (lift) = .600"):
L/2R=.600÷3.50=.171
sin=.171
Total arc = 19.74°
Boffin Emeritus
Re: Scrub path length calculation? [Re: polyspheric] #1126178
12/02/11 04:06 PM
12/02/11 04:06 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You should just post this over on the Advanced Engine Tech forum on Speedtalk.com. This place can barely handle topics like "How much do I torque my rod bolts?" these days...
Re: Scrub path length calculation? [Re: polyspheric] #1126179
12/02/11 05:59 PM
12/02/11 05:59 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I'll hang on to this for further study.
Re: Scrub path length calculation? [Re: BradH] #1126180
12/02/11 06:36 PM
12/02/11 06:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Look who's talkin
Re: Scrub path length calculation? [Re: S/ST 3040] #1126181
12/02/11 08:38 PM
12/02/11 08:38 PM
New York
New York
I wrote an Excel spreadsheet that does it automatically if you know your rocker length.
Boffin Emeritus
Re: Scrub path length calculation? [Re: polyspheric] #1126182
12/02/11 09:55 PM
12/02/11 09:55 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Look at my exhausts! This just does not look right~!
Re: Scrub path length calculation? [Re: astjp2] #1126183
12/02/11 09:57 PM
12/02/11 09:57 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Here is the intake, looks much better!
Re: Scrub path length calculation? [Re: astjp2] #1126184
12/02/11 11:35 PM
12/02/11 11:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
Those look like stock ductiel iron Hemiroid rockers Time to send them in for rocker ratio correction, rocker tip correction and blueprinting Have you check the net lift at the retainers on all of the valves yet? If not, now is a good time to do that
Re: Scrub path length calculation? [Re: MR_P_BODY] #1126185
12/03/11 11:41 AM
12/03/11 11:41 AM
BradH Offline
BradH  Offline
Look who's talkin
From a tech perspective, this forum is a shadow of its former self. I still try to post questions of a reasonably tech-oriented nature (along w/ the occasional one that veers off course ) even knowing the responses are likely to be "less than satisfactory" from a content perspective.
It is what it is... and my s.w.a.g. is the OP's tendency to be "highly formulaic" in his descriptions goes right over the heads of a good percentage of the people who remain on this forum.
Re: Scrub path length calculation? [Re: BradH] #1126186
12/03/11 01:11 PM
12/03/11 01:11 PM
New York
New York
That's why I mentioned the .xls, I figured there are people who are happy to know that it can be predicted but hate math!
Boffin Emeritus
Re: Scrub path length calculation? [Re: polyspheric] #1126187
12/03/11 04:31 PM
12/03/11 04:31 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
The formula is:
Example 1:
S=1.75-1.724
S=.026"
Example 2:
S=1.50-1.459
S=.041"
2×arcsin(L/2R)
L/2R=.600÷3.50=.171
sin=.171
Total arc = 19.74°
thanks for the post. good info.
Re: Scrub path length calculation? [Re: 9secondsatellite] #1126188
12/03/11 05:09 PM
12/03/11 05:09 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Interesting math, but how does this translate to heads, rocker arms, pushrods and valves?
Let's say that you have trial assembled your combo and done the math provided.
How do you measure scrub?
How do you correct it?
You can lengthen the valve end with lash caps (requiring shorter pushrods)
What else?
Machine to move the rocker shaft closer/further from the valve?
Try various rockers?
Machine the rocker arm pads?
Re: Scrub path length calculation? [Re: RodStRace] #1126189
12/03/11 05:22 PM
12/03/11 05:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What else?
This brings up an interesting point. My heads are -1 indys, T&D individual shaft rockers. I would have thought that the stands would be located thru the previous rocker shaft locations (after milling the pads flat). This is how the previous owner of my heads located them. I found the roller tip to be aprox .065" toward the intake side of the valves. The geometry checker from T&D lined up with-in a few thousands. However I had to mill the head and offset bore the holes that held the stands. Then we installed thread inserts. All looks close now.
Doug
Re: Scrub path length calculation? [Re: BradH] #1126190
12/03/11 05:53 PM
12/03/11 05:53 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I enjoy the 'tech oriented" questions here. If some "ar$eholes"have driven knowledgeable people from this forum, I hope that won't keep the remaining few from sharing their secrets with the rest of us. I enjoy a "mopar only" site and hope to keep it as good as it can be.
Re: Scrub path length calculation? [Re: 67_Satellite] #1126191
12/03/11 07:37 PM
12/03/11 07:37 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Thanks for the info! Don
Re: Scrub path length calculation? [Re: RodStRace] #1126192
12/04/11 02:37 AM
12/04/11 02:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What else?
I didnt do the math to find out the sweep/scrub but
with checking and some math I ended up cutting .160
off the pads on my W-5s to run the TD multi shafts
to get the minimum sweep which is about .020 now
Re: Scrub path length calculation? [Re: Cab_Burge] #1126193
12/04/11 05:29 AM
12/04/11 05:29 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The lift at the retainers should be around .620, I am getting .542-.553 and most are on the lower side. The lobe lift was .387 and the cam card shows it should have been .400. The intakes are good, its the exhausts that calculated a ration of about 1.39-1.40. It time to get the rockers done, who do I send them to and how much will this extend my budget? Tim
Re: Scrub path length calculation? [Re: astjp2] #1126194
12/05/11 02:03 PM
12/05/11 02:03 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I better keep this one but speedtalk might be the better place to post this.
Re: Scrub path length calculation? [Re: BradH] #1126195
12/09/11 04:03 PM
12/09/11 04:03 PM
BradH Offline
BradH  Offline
https://board.moparts.org/ubbthreads/show...e=0#Post6958087
Re: Scrub path length calculation? [Re: BradH] #1126196
12/09/11 04:32 PM
12/09/11 04:32 PM
Delray beach, Florida
P
Performance Only Offline
P
and there you go, the proof.
machine shop owner and engine builder
