Page 4 of 4 1 2 3 4
Re: How beneficial has wide-band O2 been to your tuning? [Re: sixpackgut] #1126105
12/15/11 03:10 PM
12/15/11 03:10 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
For those of you w/ in-car systems, how many use Innovate's LM-2? I didn't realize they had a "mixed" reputation for reliability & performance until after I purchased mine (and was unable to return it) a couple of years ago. I've been tempted on occasion to hunt up a now-discontinued LM-1, which seems to be relatively fool-proof, although not as sophisticated.
Re: How beneficial has wide-band O2 been to your tuning? [Re: sixpackgut] #1126106
12/15/11 10:40 PM
12/15/11 10:40 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I've got an Innovate LM-1 Air/Fuel Ratio Meter Kit that I no longer need and would like to sell.
I made about 20 passes on E85 so the O2 sensor still works fine, still has blue protective sheet on the screen
Here's a link to the kit http://focus.c-f-m.com/freeshippinginnovatelm-1airfuelratiometerkit.aspx
New its still $349
I'd like to get $220 out of it. PM me if interested.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: How beneficial has wide-band O2 been to your tuning? [Re: 69dart] #1126107
12/15/11 11:19 PM
12/15/11 11:19 PM
Western Pa
farmboy70 Offline
farmboy70  Offline
Western Pa
New its still $349
I ordered one yesterday
Oh well
Re: How beneficial has wide-band O2 been to your tuning? [Re: farmboy70] #1126108
12/15/11 11:59 PM
12/15/11 11:59 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
well i have a wego3 wide band and datalogger. it is the size of a credit card with a afr display on the front of it for viewing live at no extra cost like inovate seems to have addons.
i had a friend with a lm-1. now he has a wego3 also.
i got it for tuneing the injection on my zx12 ninja watching afr,rpm,manifold inlet pressure.
since it is small (not like the huge LM1 pos) it moves from car to bike to truck with ease.
first time on my car i noticed i leave the line at 15 to 1 and cross at 12.4 to 1. seems i go over 100mph and it starts to richen up bad.
with out watching this and viewing my runs shaking down the car doing the plug thing at the end of the track i was horible lean in the front part of the track.
it shown what the accelerator pump shot is doing (or not doing LOL )
it was very helpfull for lupo to restall my converter after the new motor had it flashing to 5800 rpms. he could see the print out of the whole run with shift points and launch arc.
so it is good for more than just carb work. it told me my float bowls were getting pressurized at speed. gives converter data. and above all it lets you know where you are at jetting wise and pump shot wise.
yeah you can live with out it. but i did 3 months of tuneing in two weekends. then lean it out or make it phat and see where it gets it best mph and make sure you are around that afr.
for 430 bucks it has made life real easy. from my and my brothers cycle to a pulling/street truck (the power valve shows up big time on a holey) to my duster on race gas. if i go through a O2 sensor every 2 years it is worth the 75 bucks to me.
look up the wego3 they even make one with two afr channels for each pipe at the same time for the nascar guys LOL.and tech support was real good. i got 4 emails on the weekend with answeres to questions. two saturday and two sunday.
Re: How beneficial has wide-band O2 been to your tuning? [Re: dmking] #1126109
12/16/11 12:02 AM
12/16/11 12:02 AM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
the above picture is a shot of my 10.20 run and what the afr was doing from the start to the end at 130mph. it is a nice simple usable tool with out 300 things to look at. just the basics for normal people. the third 0 to 5vdc i have not figured out what to use it for yet on the car.
Re: How beneficial has wide-band O2 been to your tuning? [Re: dmking] #1126110
12/16/11 01:34 AM
12/16/11 01:34 AM
hooziewhatsit Offline
After reading this thread, and getting fed up chasing a hesitation in my truck, I decided to piece together an LM-1 off of fle-bay. I should be able to get everything, including the RPM converter, for ~$200
If you can get the LM-1 and the RPM converter from flebay, the O2 sensor and the other needed cables (power, O2 sensor, etc) are actually cheaper direct from Innovate.
Re: How beneficial has wide-band O2 been to your tuning? [Re: hooziewhatsit] #1126111
12/16/11 05:20 PM
12/16/11 05:20 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Put me in the camp of 'WB saves time and gives instananeous info for tuning the transitions'.
For those of you that tune by going to the track or dyno, how would you do it if you didn't have a track or dyno nearby???
And I don't think this has been mentioned yet:
You can have a combo that runs really smooth, so there are no immediate clues to a 'bad' fuel curve. A WB can give you immediate insight into whether there is more potential that should be investigated.
Re: How beneficial has wide-band O2 been to your tuning? [Re: BradH] #1126112
12/16/11 09:02 PM
12/16/11 09:02 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
May I ask which ones better LM-1 or the LM-2, I plan to get one in the near future? Car will eventually run on E-85.
Keefe
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Page 4 of 4 1 2 3 4
