msd 6 or 7 #1125859
12/02/11 03:21 AM
12/02/11 03:21 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
any performance gains going from a 6 series to a 7 series msd box? my box has 137MJ/525V and the 7 series is 190MJ/535V.
Re: msd 6 or 7 [Re: mopar dave] #1125860
12/02/11 05:56 AM
12/02/11 05:56 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Don't know if this helps but we're going to piggy back a MSD power grid on our 6AL this year rather than upgrade to a 7.
Re: msd 6 or 7 [Re: mopar dave] #1125861
12/02/11 09:51 AM
12/02/11 09:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I cant say... all I've ever run was a 7al
Re: msd 6 or 7 [Re: mopar dave] #1125862
12/02/11 09:53 AM
12/02/11 09:53 AM
an8sec70cuda Offline
Nope, the 7 just has more features built in.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: msd 6 or 7 [Re: MR_P_BODY] #1125863
12/02/11 10:41 AM
12/02/11 10:41 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
might be off topic but I'm thinking of going w/ the Summit MSD, it has a built in rev limiter...all for $149
http://www.summitracing.com/parts/SUM-850610/
Coming soon!!!!
Re: msd 6 or 7 [Re: Mr.Yuck] #1125864
12/02/11 01:17 PM
12/02/11 01:17 PM
dogdays Offline
dogdays  Offline
At the risk of going off-topic, isn't that a reverse-engineered Chinese 6AL?
R.
Re: msd 6 or 7 [Re: dogdays] #1125865
12/02/11 01:29 PM
12/02/11 01:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
How about a lightly used 7530 box
Re: msd 6 or 7 [Re: Al_Alguire] #1125866
12/02/11 02:05 PM
12/02/11 02:05 PM
Mt Morris Michigan
Mt Morris Michigan
I just thought maybe the extra millijoules might make a cleaner burn and alittle more power. whats the diff. between the 7520 and the 7530 Al? currently using the summit 6 box made by mallory.
Re: msd 6 or 7 [Re: mopar dave] #1125867
12/02/11 02:25 PM
12/02/11 02:25 PM
PA
moparacer Offline
moparacer  Offline
PA
I don't know about the millijouls or whatever that is but I can switch back and forth between a 6AL and a 7AL box all day long and run the exact same ET. Done it several times clean down to 7 second ET's normally aspirated.
Boosted or Nitrous setups would be a different story.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: msd 6 or 7 [Re: Tig] #1125868
12/02/11 02:50 PM
12/02/11 02:50 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Tig I'll like to hear some feedback on the grid as i also thought of piggybacking the grid on my 6..............
Re: msd 6 or 7 [Re: racerx] #1125869
12/02/11 03:10 PM
12/02/11 03:10 PM
Mt Morris Michigan
Mt Morris Michigan
ok, maybe i'll stay with my 6 box. thanks
Re: msd 6 or 7 [Re: mopar dave] #1125870
12/02/11 03:38 PM
12/02/11 03:38 PM
Cab_Burge Online work
Cab_Burge  Online Work
The only time your going to see a measurable difference is if the 6 unit is not up to the load needed to meet your motors ignition needs That being said I'm a firm believer in having more than you need on some race parts, feul supply, valve spring pressure, tire bite and so on. I have been using the MSD 7 series boxes and appropriate coils for years on all of my cars
Re: msd 6 or 7 [Re: Cab_Burge] #1125871
12/02/11 07:24 PM
12/02/11 07:24 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
We did back to back tests this year at Norwalk. Switching to the Analog 7 and coil leaned my Hemi out considerably. ET picked up all the way down the track until the chip hit it. Go for the 7.
https://board.moparts.org/ubbthreads/show...rue#Post6826605
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: msd 6 or 7 [Re: sunroofgtx] #1125872
12/04/11 01:30 PM
12/04/11 01:30 PM
That test is inconclusive at best.
CHIP
Re: msd 6 or 7 [Re: Tig] #1125873
12/04/11 05:22 PM
12/04/11 05:22 PM
Mt Morris Michigan
Mt Morris Michigan
How much for the 7530 Al? I was looking at using the 7520 digital box. I will be using a 1050 or the SV1,so maybe the 7 box would be an advantage. My 408 is still on pump gas@10.5:1.
Re: msd 6 or 7 [Re: racerx] #1125874
12/05/11 02:43 PM
12/05/11 02:43 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Sorry to hi jack the thread but the main reason we'll be going to the Grid is 'cause we're also upgrading to a crank trigger.
The programmable functions can be found here:
http://www.msdignition.com/Products/Igni...oller_Only.aspx
I will post feedback but our season doesn't start 'til May next year
Re: msd 6 or 7 [Re: mopar dave] #1125875
12/05/11 03:37 PM
12/05/11 03:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
the 7530 is fully programmable the 7520 is not, ie rev limits timing curves etc..
