Re: 4150-4500 spacer adaptor
[Re: mopar dave]
#1125831
12/02/11 04:59 AM
12/02/11 04:59 AM
Posts: 791 Bama
Randy..
Bama
Wilson manifolds or High Velocity Heads/HVH super sucker.
[Re: AndyF]
#1125833
12/02/11 01:24 PM
12/02/11 01:24 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Man, Wilson thinks their stuff is gold I guess. I run the 2 1/4" spacer/adapter from Moroso and it`s cheap and can be blended into your plenum nicely and quickly. I can`t imagine a 1" adapter working too well w/the butterflies so close to an abrupt turn/angle but that`s me.
[Re: Thumperdart]
#1125834
12/02/11 01:31 PM
12/02/11 01:31 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
If you can't fit the tall adapter, buy a manifold w/ the 4500 flange. I don't think you'll see any gains w/ the dominator using a short 1" adapter.
[Re: AndyF]
#1125837
12/02/11 03:38 PM
12/02/11 03:38 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I run a 2" adapter that has been blended to the ported intake and it works good but have no room for air cleaner. I would like to try a 1" to see if it makes any difference in e.t. so I could possible fit a air cleaner.
67' charger 499 RB
10.57 at 127
[Re: mopar dave]
#1125840
12/04/11 05:57 PM
12/04/11 05:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On my W-2 I use a 2" adapter but on my W-9 I milled the 420 intake to take the carb direct on the manifold... I didnt think I needed more plenum volume with 405ci plus I didnt want to have to change the air pan on my scoop if I change engines(thats how much taller the 420 is over the Indy W-2)
