4150-4500 spacer adaptor #1125830
12/02/11 03:09 AM
12/02/11 03:09 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
thinking about trying a 1050 dominator next year on my indy headed 408. who makes the best 1" 4150 to 4500 spacer to fit my indy 360-3? looking for best performance.
Re: 4150-4500 spacer adaptor [Re: mopar dave] #1125831
12/02/11 04:59 AM
12/02/11 04:59 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
Wilson manifolds or High Velocity Heads/HVH super sucker.
Re: 4150-4500 spacer adaptor [Re: mopar dave] #1125832
12/02/11 01:16 PM
12/02/11 01:16 PM
AndyF Offline
AndyF  Offline
I use the Wilson adapter but it is expensive. The adapter is about 1/2 the cost of new intake. If you're going to switch to a Dominator you might want to just go ahead and buy an intake with the 4500 flange.
Re: 4150-4500 spacer adaptor [Re: AndyF] #1125833
12/02/11 01:24 PM
12/02/11 01:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Man, Wilson thinks their stuff is gold I guess. I run the 2 1/4" spacer/adapter from Moroso and it`s cheap and can be blended into your plenum nicely and quickly. I can`t imagine a 1" adapter working too well w/the butterflies so close to an abrupt turn/angle but that`s me.
Re: 4150-4500 spacer adaptor [Re: Thumperdart] #1125834
12/02/11 01:31 PM
12/02/11 01:31 PM
an8sec70cuda Offline
If you can't fit the tall adapter, buy a manifold w/ the 4500 flange. I don't think you'll see any gains w/ the dominator using a short 1" adapter.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 4150-4500 spacer adaptor [Re: an8sec70cuda] #1125835
12/02/11 02:01 PM
12/02/11 02:01 PM
Mt Morris Michigan
Mt Morris Michigan
I would like to use an adaptor so if i don't get any gains with the dom. i can just go back to my Bigs 950. thanks
Re: 4150-4500 spacer adaptor [Re: mopar dave] #1125836
12/02/11 03:18 PM
12/02/11 03:18 PM
AndyF Offline
AndyF  Offline
I understand your point, but a Dominator on an adapter isn't necessarily a true test. The intake manifolds which are designed for a Dominator usually have the plenum designed differently.
Also, 4500 intakes are usually designed as "race" intakes with raised runners and other changes. This isn't always the case though, some vendors like Indy just machine the same intake differently for the 4500 carb. On the other hand, Edelbrock intakes are usually a totally different design for 4500 carbs.
You could spend money on an adapter and not see any performance increase. But a different intake with a Dominator might pick up a bunch of power.
Re: 4150-4500 spacer adaptor [Re: AndyF] #1125837
12/02/11 03:38 PM
12/02/11 03:38 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I run a 2" adapter that has been blended to the ported intake and it works good but have no room for air cleaner. I would like to try a 1" to see if it makes any difference in e.t. so I could possible fit a air cleaner.
67' charger 499 RB 10.57 at 127
Re: 4150-4500 spacer adaptor [Re: dragram440] #1125838
12/02/11 03:56 PM
12/02/11 03:56 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I used a Moroso 2" spacer and blended it to the manifold on both my Indy and Edelbrock Super Victor, but my origional intent was to use a 1050 dominator on my 408 anyway.
Re: 4150-4500 spacer adaptor [Re: dartman366] #1125839
12/04/11 05:50 PM
12/04/11 05:50 PM
Mt Morris Michigan
Mt Morris Michigan
A few years back Ryan mentioned An adaptor he found that worked better than mounting the Dom directly on a 4500 intake,but can't remember which spacer/adaptor. Also I see Ryan has a mod for the Indy intake 4150-4500 mod. Anyone know what the cost is on this mod.
Re: 4150-4500 spacer adaptor [Re: mopar dave] #1125840
12/04/11 05:57 PM
12/04/11 05:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my W-2 I use a 2" adapter but on my W-9 I milled
the 420 intake to take the carb direct on the manifold...
I didnt think I needed more plenum volume with 405ci
plus I didnt want to have to change the air pan on
my scoop if I change engines(thats how much taller
the 420 is over the Indy W-2)
Re: 4150-4500 spacer adaptor [Re: MR_P_BODY] #1125841
12/05/11 08:01 PM
12/05/11 08:01 PM
Mt Morris Michigan
Mt Morris Michigan
So mike,do you Think I need the plenum volume of a 2"spacer on my 408 with the Indy intake with a Dom ?
