08 Ram 1500 Floor vent not working #1125161
12/01/11 06:55 PM
12/01/11 06:55 PM
Missouri
Small block fan Offline OP
Missouri
Subject says it all. Defrost works. Vents work. But no floor vents. Please help. Thanks everyone.
Re: 08 Ram 1500 Floor vent not working [Re: Small block fan] #1125162
12/01/11 09:48 PM
12/01/11 09:48 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
More than likely a broken door in the HVAC housing or posibly a faulty door actuator.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 08 Ram 1500 Floor vent not working [Re: Small block fan] #1125163
12/01/11 10:02 PM
12/01/11 10:02 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Re: 08 Ram 1500 Floor vent not working [Re: 71yelladustr] #1125164
12/01/11 11:19 PM
12/01/11 11:19 PM
S.W.Conn.
1968beepbeep Offline
S.W.Conn.
I have the same truck with the same problem, blend door broke at the pivot.
Re: 08 Ram 1500 Floor vent not working [Re: 1968beepbeep] #1125165
12/02/11 10:31 AM
12/02/11 10:31 AM
Missouri
Missouri
Ok thank you. How hard is that to fix?
Re: 08 Ram 1500 Floor vent not working [Re: Small block fan] #1125166
12/02/11 12:13 PM
12/02/11 12:13 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Earlybee gave you good advise above. Go to the heatertreater web site, watch the videos and follow the directions.
I had mine replased with their product and they are great IMO.
To remove the door on the passengers side by the floor is really easy. Replacement take awhile longer.
If your truck is still under warranty it should be covered.
