any one ever put a ford truck 9 inch in a b body #1125060
12/01/11 05:01 PM
12/01/11 05:01 PM
United states wisconsin
bigblockbryan Offline OP
buddy of mine offered me a 9 inch posi for 100 bucks housing everything, i now the perches would have to be moved and would need small pattern axel shafts its outt 76 f150.
Re: any one ever put a ford truck 9 inch in a b body [Re: bigblockbryan] #1125061
12/01/11 05:42 PM
12/01/11 05:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Measure the diameter of the tubes to see if they are
the THICK ones or not... I put a 9" in my Rampage
not to long ago... it was the larger diameter but
its what I had
EDIT
Either way a full housing with a possi is worth a $100
Re: any one ever put a ford truck 9 inch in a b body [Re: bigblockbryan] #1125062
12/01/11 06:51 PM
12/01/11 06:51 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
that rear would be too wide also so it would have to be narrowed for a b-body but for a $100 you could at least sell the posi chunk for $250+ if it is in decent condition
Re: any one ever put a ford truck 9 inch in a b body [Re: 446acuda] #1125063
12/01/11 09:40 PM
12/01/11 09:40 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
if you can find someone to narrow the housing there are cheap aftermarket axles for the 9 inch---randys sells the 9,s in any inch increment for about $100 each---so you could get a 28,29,30----if you start looking for a 28.5 inch the set will cost about $500 for a custom cut---bob
Re: any one ever put a ford truck 9 inch in a b body [Re: savoy64] #1125064
12/01/11 11:21 PM
12/01/11 11:21 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Bolt circle is likely 5 on 5.5
Edit -sorry missed that you knew that.
Re: any one ever put a ford truck 9 inch in a b body [Re: bigblockbryan] #1125065
12/02/11 12:38 AM
12/02/11 12:38 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
I will ask why do this?
First a dana is more appropriate, stronger, less costly.
Sell the 9" to someone who doesn't know better then put the money into a Dana.
Stock 9" is no stronger than a 8 3/4 or 9 1/4 that dodge uses.
It can be made quite strong with all aftermarket parts but most everyone I know who change to it from a 8 3/4 or even the bow tie guys from thier 12 bolts find now they have to spend money making it as strong as what they had.
Re: any one ever put a ford truck 9 inch in a b body [Re: fox] #1125066
12/02/11 04:51 PM
12/02/11 04:51 PM
its not being done to be stronger at all its being done because the posi chunks. are far cheaper and easier to come by. I do have access to to a machine shop too also i just rememberd i have a 57 ford ranchero rearend i got awile back.
Re: any one ever put a ford truck 9 inch in a b body [Re: fox] #1125067
12/02/11 05:00 PM
12/02/11 05:00 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
O boy here we go Not EVERY application requires a dana
Re: any one ever put a ford truck 9 inch in a b body [Re: SLOW67] #1125068
12/02/11 07:59 PM
12/02/11 07:59 PM
dogdays Offline
dogdays  Offline
A 57 Ford 9" housing is very highly sought after by street rodders. It is narrow and has a round smooth backside. Put it up for sale and get some $ out of it.
$100 for a whole 76 posi rear is a deal, go for it. I think it's probably too wide but there were earlier 4x4s that had pretty narrow housings, not to mention late model big Lincolns that also had disk brakes and I'm not talking about the Versailles. I've seen many of those at swap meets and they are pretty narrow.
Yup, the D60 or 8 3/4 is the politically correct way to go but sometimes money trumps correctness. I feel for ya.
R.
Re: any one ever put a ford truck 9 inch in a b body [Re: dogdays] #1125069
12/02/11 08:55 PM
12/02/11 08:55 PM
GA
Boosted Offline
Boosted  Offline
GA
Just a FYI for you.. You can get an 8.8 from a pull a part for 150.. The one to get comes in a ford explorer 95 up body style. Disk brakes, posi, 3:73 gears or 4.10 and 31 spline axles and they are almost the same width as your b body rear end.. maybe 1" shorter depending on the year.
59 1/2" wide on the ford explorer axle And that is rotor to rotor..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: any one ever put a ford truck 9 inch in a b body [Re: Boosted] #1125070
12/03/11 05:16 AM
12/03/11 05:16 AM
cool thanks for the advice, I think i will be getting a 8.8 im kinda building budget super bee on the budget i think im gonna use the drive line outta my fury actually.
Re: any one ever put a ford truck 9 inch in a b body [Re: bigblockbryan] #1125071
12/03/11 06:08 AM
12/03/11 06:08 AM
Goat Rodeo
drago Offline
drago  Offline
Goat Rodeo
Oh no! you must have a Dana rear end, even if it costs you more.
The Mopar police say so.
Re: any one ever put a ford truck 9 inch in a b body [Re: bigblockbryan] #1125072
12/03/11 06:47 PM
12/03/11 06:47 PM
GA
Boosted Offline
Boosted  Offline
GA
I am building a twin turbo sb 69 dart and it will have the 8.8 in it... I have put allot of spray through the old Mustang i use to have and that 8.8 held up perfectly..
2011 RAM3500
