question on taking of weight
#1124642
11/30/11 09:16 PM
11/30/11 09:16 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
Does it matter where you take it off? Is weight still weight? I'm putting glass trunk on it will take off 50lbs. I've taken weight off before not this much at once though. How much power does it take to push 50lbs?
Shawn Jennings
Re: question on taking of weight
[Re: Thumperdart]
#1124645
11/30/11 09:45 PM
11/30/11 09:45 PM
572_dup2
Salina ks
With me in car dead on 3500
Shawn Jennings
[Re: tboomer]
#1124652
12/01/11 02:17 AM
12/01/11 02:17 AM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Just take it off! The way your car launches taking it off the rear may help things a lot more than some think. Just keep taking it away from EVERYWHERE you can. If you get to a point where bias is an issue you can always ad some ballast to make it happy.
[Re: Al_Alguire]
#1124653
12/01/11 02:31 AM
12/01/11 02:31 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Yep! I agree!
[Re: Sport440]
#1124654
12/01/11 04:41 AM
12/01/11 04:41 AM
Posts: 687 Ohio
Chad Bittle
Ohio
It's gonna change the geometry of your chassis/suspension...how much weight it would have to be to make a difference I'm sure depends each person's setup.
[Re: AndyF]
#1124655
12/01/11 08:03 AM
12/01/11 08:03 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Yes it matters. On a RWD drag car you want to take weight off the nose of the car first.
Not always, Andy. At 9.0 to 8.88 ET to settle my wheelstander down I moved so much weight forward I thought it would never hook. I not only put on a glass trunk lid, but also went lexan on the rear window, and moved the battery from the trunk to in front of the radiator! Car settled right down, and all I had to do is raise the launch rpm. That was a move from 50/50 to 53 percent front 47 percent rear. Pretty radical to say the least. 60 fts picked up, because it doesn't unload the rear tires now when the wheelie bars hit. First three passes after the change, 1.263, 1.260, 1.259. The lesson I learned was that if you can transfer weight and have the torque to KEEP it transferred, the car will never know the difference!
[Re: gregsdart]
#1124656
12/01/11 09:50 AM
12/01/11 09:50 AM
572_dup2
Salina ks
Since i changed rear tires seems that traction is better on ify tracks. Got the big wheelies under control. If it dont like that much weight off the rear i could always add some. My car is just so heavy it hard to take off weight an still keep it looking like a car.
Thanks for the advice an tips!!
Shawn Jennings
[Re: jim sciortino]
#1124659
12/01/11 06:11 PM
12/01/11 06:11 PM
572_dup2
Salina ks
Soak an wet with my pockets full I'm $1.70
Shawn Jennings
[Re: 572_dup2]
#1124660
12/01/11 06:27 PM
12/01/11 06:27 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
That's not enough to make a car very light.
[Re: ]
#1124661
12/01/11 09:18 PM
12/01/11 09:18 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
100 LBS. is a .1 off ET.
old wives tale hardly ever means a tenth
[Re: mcat4321]
#1124662
12/01/11 09:35 PM
12/01/11 09:35 PM
572_dup2
Salina ks
If its worth .01 im happy. Maybe it takes 7hp to carry that 50lbs well thats 7hp less i gotta make.
Shawn Jennings
[Re: 572_dup2]
#1124663
12/02/11 09:37 PM
12/02/11 09:37 PM
fullmetaljacket
I'm 175 wet with chump change in the pockets. A little bird told me that an early B-body can be brought down to the thin line of 3100 lbs while keeping all steel parts. Like said things like bolts, nuts, washers, cutting out access fat in panels that are not structural, Bubble windshields, Lexan windows with aluminum tracks that actually roll up and down like stock, aluminum interior panels, all undercoating, sound deadening removed, Aluminum hood pins, lightweight bumper brackets, aluminum radiator and aluminum front valance panels, aluminum steering column, lightweight center links, you name it and soon enough it will be a contender. Like you said 572, why have to make more horses when you can take the weight loss courses.
[Re: fullmetaljacket]
#1124664
12/02/11 10:39 PM
12/02/11 10:39 PM
572_dup2
Salina ks
What I have left that weights the most is bench seat. But I refuse to take it out.
Shawn Jennings
[Re: 572_dup2]
#1124665
12/02/11 11:31 PM
12/02/11 11:31 PM
Sport440
Canton, Ohio
When removing weight, dont just focus on one thing. Its the hundreds of little places that can all add up.
Keep the seat, but study it and it can even be lightend a bunch without anyone noticing.
[Re: 572_dup2]
#1124666
12/02/11 11:59 PM
12/02/11 11:59 PM
fullmetaljacket
Like sport440 said, study the seat. I know that the bench seats weigh exactly 100 lbs. I had one in mine, out it came and in its place came the A-100's with hardware. See if you can take weight out of the half that you do not sit on and fabricate it to look like factory stock. I would. The F.A.S.T guys have some of these tricks up their sleeves I'm sure. Lighten the front by fabricating the grille to resemble the 64'Hemi A-864 mug. Gut the hood to only the skin and re-inforce where the hood hinges poke through. Aluminum strut rods, gutted glove box door, shorten all wiring harnesses, Plastic head lights, Aluminum door hinges, I know a guy that makes them just like the Factory, (Your doors should be lighten as well to accommodate the hinges because they may weaken with stock door weight) aluminum brackets for all the accessories on motor, Thin wall aircraft stainless 304 tubing for the exhaust, Aluminum exhaust hangers, Anodized aluminum cover for the Dana rear, Braile battery,
#1124667
12/03/11 10:45 AM
12/03/11 10:45 AM
572_dup2
Salina ks
There is nothing behind doors panals or panals in the rear nothing..lol no headlights its decals. Have light weight battery. Bumpers are both fiberglass with aluminum brackets. Its all lexan no glass. Nothing under the dash. Never thought of aluminum door bracket good idea! Passenger side of seat is gutted underneath.
Shawn Jennings
