question on taking of weight
#1124642
11/30/11 09:16 PM
11/30/11 09:16 PM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
Does it matter where you take it off? Is weight still weight? I'm putting glass trunk on it will take off 50lbs. I've taken weight off before not this much at once though. How much power does it take to push 50lbs?
Shawn Jennings
Re: question on taking of weight
[Re: Thumperdart]
#1124645
11/30/11 09:45 PM
11/30/11 09:45 PM
572_dup2
Salina ks
With me in car dead on 3500
Shawn Jennings
[Re: tboomer]
#1124652
12/01/11 02:17 AM
12/01/11 02:17 AM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
Just take it off! The way your car launches taking it off the rear may help things a lot more than some think. Just keep taking it away from EVERYWHERE you can. If you get to a point where bias is an issue you can always ad some ballast to make it happy.
[Re: Al_Alguire]
#1124653
12/01/11 02:31 AM
12/01/11 02:31 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Yep! I agree!
[Re: Sport440]
#1124654
12/01/11 04:41 AM
12/01/11 04:41 AM
Posts: 687 Ohio
Chad Bittle
Ohio
It's gonna change the geometry of your chassis/suspension...how much weight it would have to be to make a difference I'm sure depends each person's setup.
[Re: AndyF]
#1124655
12/01/11 08:03 AM
12/01/11 08:03 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Yes it matters. On a RWD drag car you want to take weight off the nose of the car first.
Not always, Andy. At 9.0 to 8.88 ET to settle my wheelstander down I moved so much weight forward I thought it would never hook. I not only put on a glass trunk lid, but also went lexan on the rear window, and moved the battery from the trunk to in front of the radiator! Car settled right down, and all I had to do is raise the launch rpm. That was a move from 50/50 to 53 percent front 47 percent rear. Pretty radical to say the least. 60 fts picked up, because it doesn't unload the rear tires now when the wheelie bars hit. First three passes after the change, 1.263, 1.260, 1.259. The lesson I learned was that if you can transfer weight and have the torque to KEEP it transferred, the car will never know the difference!
[Re: gregsdart]
#1124656
12/01/11 09:50 AM
12/01/11 09:50 AM
572_dup2
Salina ks
Since i changed rear tires seems that traction is better on ify tracks. Got the big wheelies under control. If it dont like that much weight off the rear i could always add some. My car is just so heavy it hard to take off weight an still keep it looking like a car.
Thanks for the advice an tips!!
Shawn Jennings
[Re: jim sciortino]
#1124659
12/01/11 06:11 PM
12/01/11 06:11 PM
572_dup2
Salina ks
Soak an wet with my pockets full I'm $1.70
Shawn Jennings
[Re: 572_dup2]
#1124660
12/01/11 06:27 PM
12/01/11 06:27 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
That's not enough to make a car very light.
[Re: ]
#1124661
12/01/11 09:18 PM
12/01/11 09:18 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
100 LBS. is a .1 off ET.
old wives tale hardly ever means a tenth
[Re: mcat4321]
#1124662
12/01/11 09:35 PM
12/01/11 09:35 PM
572_dup2
Salina ks
If its worth .01 im happy. Maybe it takes 7hp to carry that 50lbs well thats 7hp less i gotta make.
Shawn Jennings
