NE1 here repair there leaking 4.7 exh manifold? #1124441
11/30/11 01:06 PM
11/30/11 01:06 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I'm about to tackle it and I'm finding out no part stores carry replacement manifolds. i see them on e-bay, would rather use the old ones if they are not cracked or warped. any ideas for a supplier. Thanks
Re: NE1 here repair there leaking 4.7 exh manifold? [Re: ademon] #1124442
11/30/11 01:35 PM
11/30/11 01:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Huh ?? Supplier for what ???
Re: NE1 here repair there leaking 4.7 exh manifold? [Re: ademon] #1124443
11/30/11 01:42 PM
11/30/11 01:42 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Did mine a year ago, and just had the sealing surfaced shaved. It sure had lost some layers though. Did a ford triton this year(very similar to 4.7), and that guy got the new manifold from napa auto parts. Oh yeah, the dakota had the Y-pipe flange rusted bad too, so I got one of those hokie 2 piece ones from parts store, instead of having to replace the Y pipe.
Re: NE1 here repair there leaking 4.7 exh manifold? [Re: JohnRR] #1124444
11/30/11 01:42 PM
11/30/11 01:42 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Most of the time it is just broken exhaust bolts, these and Hemis are notorious for that problem. Your manifolds should be ok. New bolts, stud, nuts, gaskets and heat shield should fix you right up. Hopefully none of the bolts are broken too deep it the head.
Re: NE1 here repair there leaking 4.7 exh manifold? [Re: JohnRR] #1124445
11/30/11 01:43 PM
11/30/11 01:43 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I've done both of mine. Left side about two years ago and right side last month. Left side was only leaking @ the rear. I Draw filed it flat., might be worth having it machined if you have a source. The right side was leaking @ the rear and the front. front lower bolt was broke. The right side was about an 1/8" warped. center looked good, front and rear were out. again I file them as flat as i could get and reinstalled. We'll see how it goes.
Re: NE1 here repair there leaking 4.7 exh manifold? [Re: Mr340] #1124446
11/30/11 01:51 PM
11/30/11 01:51 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
What years have these issues? I have a 2008 Ram with the 4.7L.
Re: NE1 here repair there leaking 4.7 exh manifold? [Re: Sunroofcuda] #1124447
11/30/11 04:49 PM
11/30/11 04:49 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
most years i think on the 4.7
Re: NE1 here repair there leaking 4.7 exh manifold? [Re: ademon] #1124448
11/30/11 06:47 PM
11/30/11 06:47 PM
chicagoland,usa
chicagoland,usa
Think that's why the so Cal members pick on us?......I don't care!!!
