Firing Order 2000 Ram 1500 5.9 engine #1124413
11/30/11 12:04 PM
11/30/11 12:04 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Is the firing order the same on a 2000 5.9 Magnum as the older small block LA motors?? I changed the plugs and air filter and now it won't idle.I'm thinking I may have crossed a plug wire. I am also wondering how to adjust the idle? Idon't see a screw to set it like the old carb. models.
Howard
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: Howard] #1124414
11/30/11 12:10 PM
11/30/11 12:10 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Yes it's the same.
Idle cannot be set like a carb. The PCM has a target idle speed, ad adjusts the idle air solenoid to allow more or less air to the motor to adjust the idle to target. Its also a "learned" adjustment, the computer learns over time where to set the solenoid for target idle. If you had the battery off, then the PCM "lost" the memory, and has to re-learn idle. This may require some 2-foot driving to keep it from stalling until it re-learns.
**Photobucket sucks**
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: Howard] #1124415
11/30/11 03:37 PM
11/30/11 03:37 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Were you getting a mis-fire code before you changed plugs?
If the idle was a little unstable before you changed plugs, change out the cap and rotor. Had the same problem with my '01. Rotor was pooched.
Mo' Farts
Moderated by "tbagger".
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: Grizzly] #1124416
11/30/11 05:46 PM
11/30/11 05:46 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Thanks Kaptain Kuda and Grizzly for your help. The battery was dead after I changed the plugs so I had to charge it. I will check to see if I crossed a plug wire and also check the rotor and cap.I also will try and drive it to see if the computer needs to reset. It did not have the power that I think the 360 should have and got really bad gas mileage. I had a 2002 Durango with a 4.7 and it would have run rings around this one. Thanks again
Howard
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: Howard] #1124417
11/30/11 05:51 PM
11/30/11 05:51 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Yes, firing order is the same.1,8,4,3,6,5,7,2 clockwise rotoation. #1 cylinder on left,D/S with the other odds, even on the right. #1 cylinder position on distributor cap is (if looking over the top) just left of the square looking side of the cap where it bolts to distributor. HTH
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: wheelsup68dart] #1124418
11/30/11 07:25 PM
11/30/11 07:25 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
if your battery was dead, and you swapped it out, then your PCM is already set and yes, you might have to 2-foot it for a few days till it re-learns idle.
cap/rotor is routine maintenance on these too.
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: 70Cuda383] #1124419
12/01/11 01:59 AM
12/01/11 01:59 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Any chance you dropped a plug and closed up the gap without noticing? Seen that before. Also had an Autolite plug that had the insulator flopping around in the steel. It still ran, but it had what sounded like a valve ticking. Knew something was up when I was pulling wires off and this one practically fell off and was burnt from compression blowing at it. That and the fact that the insulator was flopping around...
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: Howard] #1124420
12/01/11 02:21 AM
12/01/11 02:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Those were known for sucking oil in the intake... also
check the under side of the throttle body for carbon
which screws up the idle air motor... clean that with
carb cleaner or brake cleaner... also see if you get
a O2 code... the O2 sensor could be fouled which
will give bad performance and bad mileage
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: MR_P_BODY] #1124421
12/01/11 10:20 AM
12/01/11 10:20 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
if you have oil in the intake, chances are you need to pull the intake and repair the gasket on the bottom plenum. (the intake is cast with an open bottom, then it's sealed with a sheetmetal cover and a paper gasket and about 10 bolts) when that goes out, the engine sucks oil up from the valley, fouls out plugs, kills fuel mileage, makes the engine ping under WOT, and make you think that the 360 is a dog.
I didn't mention that before, figured the issue was just old worn out plugs
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: 70Cuda383] #1124422
12/01/11 11:19 AM
12/01/11 11:19 AM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Kaptain, the old plugs I took out looked good, the only problem I had was removing #3 plug the tin cylinder that the plug fits in would not let the socket on the plug enough to get it out so I tapped the socket on. maybe I should pull that one back out and check it. I prob. have to two footed it like you said. there was no oil or carbon on any of the old plugs and the electrodes all looked good and the gap on all was .040 to .045. IT has a drain somewhere and sometimes after only sitting a week or two the battery is dead. When I bought the truck a year ago I just thought the battery needed replacing. After paying 95 dollars for a new one I found that not to be the case. I'm an old dirt that does not know crap about working on todays motors.
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: Howard] #1124423
12/01/11 12:21 PM
12/01/11 12:21 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
ok, if your old plugs looked good, then your intake plenum gasket is probably fine. as P-body said though, open the throttle plates on the TB and look down with a flashlight. should be dry.
the good news about the 5.2 and 5.9L engines, is that they're exactly the same as the old 318s and 360s. there's a few minor differences like stud mounted rockers vs shaft mounted rockers, oil through pushrods, roller cams, but those are all very minor changes. the most dramatic thing is the EFI intake manifold. once you figure out what the engineers were thinking with the programming, they're easy to work on!
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: 70Cuda383] #1124424
12/01/11 06:52 PM
12/01/11 06:52 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
If you suspect the intake/pan gasket leaking, try this test.
with the engine running, remove the oil fill cap and lay a thin piece of paper-like a napkin-- over the hole. It should pus out, NEVER draw in. If it draws in the gasket most likely is the problem.
BTW, I owned two different magnum engines that had the gasket changed under warrantee.
both still leaked and I got a good deal on those trucks.
Pulled the intake and found the 'mechanic', 'trouble shooter', 'parts changer, didn't pay attention to his own work.
On both, the bolts bottomed out before the washer contacted the pan on MOST bolts.
Apparently the holes were not drilled deep enough!!!
I simply added two washers to each and checked each before final torque.
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: fox] #1124425
12/04/11 11:53 AM
12/04/11 11:53 AM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Kaptain Kuda was right after checking everything again and it still shutting off I two footed it for a couple of miles and now the PCM must have reset because it isn't stalling and is running very smoothly. Thanks for all the suggestions, I really appreciate it.
Howard
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: Howard] #1124426
12/04/11 01:40 PM
12/04/11 01:40 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Howard
Glad you got it worked out!
FYI, any time the battery is run dead, or disconnected for other maintenance, etc. this will happen.
Re: Firing Order 2000 Ram 1500 5.9 engine [Re: Howard] #1124427
12/04/11 01:52 PM
12/04/11 01:52 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Most of all Howard, thank you for the update! It helps everyone out.
Sometimes we get on here and offer advice and solutions and never hear back from the from the person asking for help.
Mo' Farts
