Re: Subframe connectors, which way should we
[Re: ZIPPY]
#1123
11/24/04 08:44 PM
11/24/04 08:44 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
More pics to add since the old ones are all dead...
This is the outrigger + main hoop installation
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1124
11/24/04 08:49 PM
11/24/04 08:49 PM
ZIPPY
S.E. Michigan
This is the full roll bar.
Kicker bars are welded to the frame tie.
Side bars are welded to front outriggers (2x3 stub welded between the rocker and the frame rail)
The only pieces that are sitting on plates are the two rear bars, in the trunk...everything else is part of the structure.
The eventual need for a roll bar was a real deciding factor when doing the frame ties this way....it paid off to plan ahead.
Rich H.
Esse Quam Videri
[Re: rapom]
#1126
11/25/04 04:38 PM
11/25/04 04:38 PM
Posts: 477 Clarkston,MI
Todd_DesMarais
super street
super street
Clarkston,MI
Holly Crow, IT'S STILL ALIVE !!!!! Good job John, I'm a bit supprised that you welded the floor on the bottom also. and yes the pics I sent you were of the "Zippety Doo Dah's" car sorry Rich, had to say it. Todd
aduC' 47
IIeredevleB 66
383 etilletaS 66
DTC 0053 MAR 50
"ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
[Re: Todd_DesMarais]
#1127
11/25/04 05:31 PM
11/25/04 05:31 PM
Posts: 1,883 Northern OH
rapom
Northern OH
I also thought it was a little overkill but I welded both sides because I wanted it to look cleaner. I also mini tubbed and moved leaf springs into the frame rails last winter. This fall I replaced some of the trunk floor and cleaned off the sounddeadener on the inside quarters. I wanted to sandblast and paint the undercarrage but it now seems a little to cold for putting on the Zero Rust since it has to be above 50 to use it. My next big jobs this winter are to replace the lower rear quarters and fill in the trim holes down the side of the car. This pic is of some 325/50/15 drag radials that fit in the tubs nicely now. The car will be sitting a lot lower than the pic shows though. Did you do any work to your 66 yet.
[Re: rapom]
#1128
11/26/04 11:16 PM
11/26/04 11:16 PM
Todd_DesMarais
super street
super street
Clarkston,MI
"it has to be above 50 to use it." three words, Radiant Tube Heater I love the lines of a coronet 'specially with meats in the back ! As for work on mine, well.....I did get it to the house this summer and have removed the hacked on drivers rocker panel. it was repaired from an accident and obviously done by someone who either didn't care, or had no idea of how to do a quality job. they "removed" some of the damaged rocker with a chisel and put one from another car over it by using a hammer and brazing rod. so I picked up a parts car for the rocker and a-pillar door post (piece where the vin tag is riveted) since mine has a slight inward bend to it. I'll ship a few pics . Todd
aduC' 47
IIeredevleB 66
383 etilletaS 66
DTC 0053 MAR 50
[Re: rapom]
#1132
04/13/05 02:27 AM
04/13/05 02:27 AM
hmmm interesting i did mine completly different i used 3x3 cut the flour pan, and on the rear of the original frame its L shaped at the flour pan then i welded in 1/4 x 3 x 8 inch plates to the original rear frame and rear conector.then in the front on the scrossover the flour pans on the front are cut out so i boxed the tranny crossmember witch looks flimsy anyways and added gussets to the inside of it to make it more riggid then i welded the front of the connector to it.After that i welded in a 3x3 in the back across the frame at the shock crossmember and cut the old thin cheep shock crossmember out and added gussets to the frame as well,then i went back in side and welded 2x3 from the rear of the frame conector across over the tranny hump and back to the other frame conector and added gessets so now the the tranny crossmember (that i boxed in) and the frame connectors are all one piece in both directions .then i added 1/8 x4 to the inside of the frame ralls from the trans crossmember all the way's to the radiator crossmember and trimed it to match the frame the car is solid as a rock Next i'm going to start drilling holes every place i can to loose weight.
[Re: Dos Snails]
#1134
04/14/05 12:42 PM
04/14/05 12:42 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I guess I'll participate & keeps this one going also. There is another thread going right now on frame connectors also. The is what I did with mine. I have done mine a totally different way then everyone else. It was alot of extra work. But I am going for that sleeper look (if that is possible with a HEMI car!!!!) I want the all stock look. I cut off the rocker panels of my 70' Challenger & hid the 2"x3" tubing inside the body. I tied it into the transmission cross member body support at the front stitch welded along the entire body & into the side of the rear frame rails at the rear. I obtained an original set of factory E-body boxed in spring perches from an original HEMI parts car. Once I installed these the only way to tell the car has been frame connected is to look into the small square hole from underneath that is there to mount the rear leaf spring mounts. It came out awesome but was alot of work. The car is still on the rotisserie as of now completely stripped & there is no body flex at all.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: rapom]
#1136
04/15/05 12:16 PM
04/15/05 12:16 PM
6PKRTSE
Motor City
Yes it was. But it is probably going to be a 10 second all steel,full interior,all stock appearing street car. To modified to run pure stock. I will probably do the same thing to my Charger when I finally restore it someday. But for now I just made some quick welded 1-1/2"x2" connectors like everyone else has when I put the HEMI in the Charger. They definately make a difference. Frame connectors should of been factory for big block cars.
[Re: mopurist]
#1138
09/08/05 03:12 PM
09/08/05 03:12 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Check out the ones from US CARTOOL designed to be welded directly to your floor. They look great.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: mopurist]
#1140
09/08/05 06:37 PM
09/08/05 06:37 PM
Posts: 1,913 Brunswick, Jawgia
Snailpower
Infinitely Fast Snail
Brunswick, Jawgia
I just got a set of them at the Nationals and I must say I am impressed. I have not had a chance to install them yet, but I can't wait. Funny thing is, I just finished some 2x2 connectors on my wagon, which made a big difference in the car WITHOUT tying into the floor. The Coronet is much faster and will see dragstrip duty, so the US Car and Tool frame connectors is the way to go for the turbo car. Besides, John at US Car and Tool is great to deal with!
70 Coronet- turbocharged 360/518/3.73 SG
