NE1 R and R a 2000 LHS tranny #1123844
11/29/11 12:40 AM
11/29/11 12:40 AM
Wichita Kansas
6PacCuda Offline OP
6PacCuda  Offline OP
Wichita Kansas
The transmission is going out in my Aunts 01 LHS and I was wondering how bad it is to R and R the tranny. I have a two post lift and have done tons of front drive trannys but this one looks to be more of a pain. Just wondering what to look for when I start this project. Can it be done without dropping the cradle.
Re: NE1 R and R a 2000 LHS tranny [Re: 6PacCuda] #1123845
11/29/11 04:58 PM
11/29/11 04:58 PM
Pittsburgh, PA
1970440RT Offline
1970440RT  Offline
Pittsburgh, PA
Just did one on an 02 Intrepid. It is longitudinal, not transverse so it comes out like a rear wheel drive trans, pretty much the only difference is popping out the half shafts instead of disconnecting the u joint. It was easier than most front drives I have done. Also, you do not have to drop the cradle, just the trans crossmember and mount.
Re: NE1 R and R a 2000 LHS tranny [Re: 1970440RT] #1123846
11/29/11 08:56 PM
11/29/11 08:56 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
And the exhaust system has to come out.
