Re: transmission question #24
[Re: 70Challengerse]
#1123824
11/29/11 12:58 AM
11/29/11 12:58 AM
Posts: 3,688 Alexandria,La.
BigTerry
Alexandria,La.
The pumps are the same, does it try to stall in reverse.. if so could be a cross leak in the pump causing the converter coming on...wiring should be the same..triangler transducer and pressure solenoid should be the same, bolt in.
never heard of a cross leak before can you give me some info on that? no it never try to stall except one time I was turning hard on the steering wheel once.. it like a roar but not quite.. well it like a whine...
[Re: JohnRR]
#1123829
11/29/11 02:36 AM
11/29/11 02:36 AM
BigTerry
Alexandria,La.
The whine is the regulator valve buzzing in the valvebody , the fix is to swap the valve body. Take the valve body from the 01 trans and put it in the 99 trans , if the problem persists it's the trans.
Yes the 2001 trans will work fine in your 99 .
Wow! I couldn't put in some trans X in it? I had the trans rebuilt 3 years ago and had the solenoid replace last year.. I'm really hoping it something simpler...sigh.. I don't think I can change the valve body not that good with trans...
#1123830
11/29/11 02:39 AM
11/29/11 02:39 AM
BigTerry
Alexandria,La.
the fix is to swap the valve body''' not really transgo makes a shift kit correct this problem...this is kind alike fixing an ailing patient over the phone...
You right it hard to diagnose a problem when it can't be full explained what it doing! Thanks guys! can I run it like it is? I don't tow with the truck or abuse it..
