direct wire from battery to coil for ignition spark ? #1123641
11/28/11 08:24 PM
11/28/11 08:24 PM
USA
I
ignoble Offline OP
ignoble  Offline OP
I
USA
I need to move my truck about 100 feet so i can get it into a garage.
1977 Dodge.
The ignition switch used to be tempermental, and i haven't moved the truck in a few months. The coil / plugs / wires / cap / rotor are new. Turn the key and nothing happens, not even a click. BAttery is just off the charger, practically new and shows 12.7 volts.
I have the dash gages pulled out to replace a few of them. So ammmeter and voltmeter are not hooked up, just electrical taped over.
I don't want to get into troubleshooting or replacing anything at the moment. I just want to move the rig and troubleshoot later. Have a 'remote starter trigger switch' hooked up to the starter solenoid lead so i can crank it over.
I Think i've bypasseed the ballast resistor before and ran a wire directly from battery to coil[+] for juice in the past.
Am i remembering correctly ?
Again, i just want to run the truck for a few minutes, for a 100 ft relocate to dry garage.
Thanks.
Re: direct wire from battery to coil for ignition spark ? [Re: ignoble] #1123642
11/28/11 08:31 PM
11/28/11 08:31 PM
Andrewh Offline
Andrewh  Offline
you can do that to get it going.
don't forget to unhook it or you will burn out the coil.
you could also connect the 2 lines from the amp meter together and you should get power to start.
Re: direct wire from battery to coil for ignition spark ? [Re: ignoble] #1123643
11/28/11 08:32 PM
11/28/11 08:32 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That will work. Just make sure you dont have any loose exposed hot leads under the dash that could short if bumped.
Re: direct wire from battery to coil for ignition spark ? [Re: ignoble] #1123644
11/28/11 08:36 PM
11/28/11 08:36 PM
5 pin ECU/4 terminal ballast? Yes you could run 12V to coil positive and 2 pins on a 5 pin ECU need fire also. See the archives. (1 pin if a 4 pin ECU). move it as fast as you can
Re: direct wire from battery to coil for ignition spark ? [Re: RapidRobert] #1123645
11/28/11 08:43 PM
11/28/11 08:43 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yep, forgot about the ecu,
Re: direct wire from battery to coil for ignition spark ? [Re: Sport440] #1123646
11/28/11 08:57 PM
11/28/11 08:57 PM
USA
I
ignoble Offline OP
ignoble  Offline OP
I
USA
Yes 5 pin ECu / 4 post ballast.
Well nothing is coming out of the coil to distributor lead [ i have it taped close to metal bracket for A/C compressor to check for spark ]
Will have to go look into the archives
I know this is hokey way of doing things....
Re: direct wire from battery to coil for ignition spark ? [Re: ignoble] #1123647
11/28/11 09:00 PM
11/28/11 09:00 PM
You're fine. Get it under wraps & holler back anytime & we'll try our damnest to get it up & running for you
Re: direct wire from battery to coil for ignition spark ? [Re: RapidRobert] #1123648
11/28/11 09:26 PM
11/28/11 09:26 PM
USA
I
ignoble Offline OP
ignoble  Offline OP
I
USA
I can't find what i need in the archive. ECU pin explanation.
I'm going to save up some $ and ask santa for an MSD box/ distributor/ coil / and wires like i put on my other car. It worked first crank, directions were straightfoward, troubleshooting wasn't necessary.
Thanks guys.
Re: direct wire from battery to coil for ignition spark ? [Re: ignoble] #1123649
11/28/11 10:03 PM
11/28/11 10:03 PM
jump fire to (1) the "point" of the ECU (red wire) and not to the black/yellow next to it but the next one over, (2) the dark green
Re: direct wire from battery to coil for ignition spark ? [Re: RapidRobert] #1123650
11/29/11 12:34 AM
11/29/11 12:34 AM
USA
I
ignoble Offline OP
ignoble  Offline OP
I
USA
Thanks RapidRobert , will try tommorow in the daylight.
Re: direct wire from battery to coil for ignition spark ? [Re: ignoble] #1123651
11/29/11 12:38 AM
11/29/11 12:38 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
We use to call that "Hotwired" perhaps you've heard the term...
