Re: what would cause a pushrod to break in half [Re: Tadams] #1123577
11/30/11 05:14 PM
11/30/11 05:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hi Grant, Thats a scarry feeling. I bought this car about 6 months ago and did have it running but never more than a fast idle. It actually idled fairly smooth and showed good oil pressure. I was checking things and the vacumm while around 20 lbs would rapidly jump from 19 to 21 so I knew somwthing was up. I thought a good valve adjustment would take care of it. When I pulled the covers and started to adjust I noticed the 7 intake wasn't moving and the rod was beside the rocker arm. I shut it off and thought I would just adjust it to where I could slip it over rhe rod. When I touched it it dropped out of site. The bottom piece was stuck in the lifter as it should be and I was able to lift the pcs out. Now I am putting it back together and pray there is no damage other than that.
When you buy an old car that has been setting you have kno idea what you have.
Have a good day and keep the rev's down a little.
Tommy
If you were to switch plug wires on 5 and 7 it really
doesnt change alot so if you lost #7 it MAY still
idle fair but you would notice it at higher revs
Re: what would cause a pushrod to break in half [Re: MR_P_BODY] #1123578
11/30/11 10:40 PM
11/30/11 10:40 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Well, I replaced the push rods, adhusted the valves, Changed the oil and filter, and installed new plugs. I was really surprized how good this thing runs now. The vacumm is 19 and steady. The car starts easy and seems to have plenty of power. Now I get to go back to replacing the leaf springs with new ones. Thanks everyone for your help, especially rapidrobert for going out of his way to answer all of my questions.
Re: what would cause a pushrod to break in half [Re: mopar_man] #1123579
11/30/11 10:48 PM
11/30/11 10:48 PM
Goat Rodeo
drago Offline
drago  Offline
Goat Rodeo
Hi,
there's no offset on the 273 solid lifter rocker arms. The hydraulic type were all offset including the TA arms.
Re: what would cause a pushrod to break in half [Re: drago] #1123580
12/01/11 09:12 AM
12/01/11 09:12 AM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
I didn't see any differance in the rockers, but sure wanted to make sure before this happened again. I didn't find any thing that would show me what caused it. All I can say is it sure runs good now.
Re: what would cause a pushrod to break in half [Re: Tadams] #1123581
12/01/11 11:30 AM
12/01/11 11:30 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
probably just spun the heck out of it, over revved.
I never saw one break myself, usually it's the rocker arm that lets go right in the push rod cup.
I have mechanical Aptitude.
I can screw up anything.
Re: what would cause a pushrod to break in half [Re: bboogieart] #1123582
12/01/11 11:33 AM
12/01/11 11:33 AM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
As I said, I bought it from someone so have no idea how it was treated before. She sure sounds great now. I can't wait to get her on the road.
Re: what would cause a pushrod to break in half [Re: Tadams] #1123583
12/01/11 11:36 AM
12/01/11 11:36 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yeah I was just tossing out my guess. Glad it was not too bad, and it's running good. Have fun with it.
Re: what would cause a pushrod to break in half [Re: Tadams] #1123584
12/01/11 03:45 PM
12/01/11 03:45 PM
Winnipeg
O
OneOfMany Offline
OneOfMany  Offline
O
Winnipeg
Good to hear it was nothing expensive
Grant
