Couple 69 valiant ?s #1123490
11/28/11 04:41 PM
11/28/11 04:41 PM
ohio
flynbyu Offline OP
flynbyu  Offline OP
ohio
What other car shares the same wheel well opening as a 69 valiant ....can't find 1/4s for it so I'm gonna have to piece this one together.......and is the trunk on a valiant the same as a 67-6969 dart other than the badge mounting ? Thanks
Re: Couple 69 valiant ?s [Re: flynbyu] #1123491
11/28/11 11:00 PM
11/28/11 11:00 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Other than the roof and doors, 67-69 Darts and Valiants do not share any exterior sheet metal.
You are pretty much limited to 67-69 Valiant for quarter panels. If you just need from the wheel opening back, you could also check Valiant 4 doors, '67-72 (the side marker lights move around almost yearly). Trunk floor is probably the same as a Dart, but the trunk floor extensions are different. Dart and Valiant trunk lids are no where close.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Couple 69 valiant ?s [Re: flynbyu] #1123492
11/29/11 01:28 AM
11/29/11 01:28 AM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
trunk lid is def different lmk if ya need a lid i have a couple---- 1/4s not so much but theyre different as well
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Couple 69 valiant ?s [Re: flynbyu] #1123493
11/30/11 12:37 AM
11/30/11 12:37 AM
The Scratch, WA
P
Part_Stalker Offline
P
The Scratch, WA
There is one side for a 69 on Seattle's Craigslist for $100.
Re: Couple 69 valiant ?s [Re: Part_Stalker] #1123494
11/30/11 01:06 AM
11/30/11 01:06 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
AFAIK, there aren't any die stamped lower quarter patch panels, much less full quarter panels.
Re: Couple 69 valiant ?s [Re: Part_Stalker] #1123495
11/30/11 12:55 PM
11/30/11 12:55 PM
ohio
flynbyu Offline OP
flynbyu  Offline OP
ohio
Thanks for the leads and info .....I'm restoring this car for my uncle ....tryin to save 1 from hitting the boneyard ...
Re: Couple 69 valiant ?s [Re: flynbyu] #1123496
12/01/11 02:49 PM
12/01/11 02:49 PM
s.e. MI
P
partsforsale Offline
P
s.e. MI
If you're only talking about the rear wheelwell area below the side body line then '70-'74 duster sheetmetal should work.
Re: Couple 69 valiant ?s [Re: partsforsale] #1123497
12/01/11 06:30 PM
12/01/11 06:30 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Should be about the same back at the bumper edge, but I think the wheel opening edge may be slightly different, and the overall length of the 2 may be different. But yes, that may be as close as you can get.
