69 8.75 Axle markings, codes, etc #1123206
11/28/11 08:37 AM
11/28/11 08:37 AM
DFW
68RRFlyer Offline OP
DFW
Hey Folks,
I'm tearing into my 69 Charger RT/SE (original, unrestored, bought from original owner so I know the car's never been apart) and degreased the rear axle and found several markings. I have a few questions that I need some confirmation on:
1. It appears that my 3 digit axle code on the driver's side tube has weathered away. I do not have a broadcast sheet to find the code. My car has the A36 axle package (3.55 Sure Grip) so I was thinking my code should be 594. Is that right?
2. I found several markings on my center chunk including my carrier's build date of 11-26 clearly visible under the left side rid. Orange blop by the fill plug, and I see evidence of stripes on the underside of the carrier. It appears there are 3 White and 1 Orange on the underside of the carrier with the orange one being the rear most stripe. These are pretty large stripes. I know it represents the ratio and if it's a Sure Grip or not. Is it 3 white for 3.55 and the orange is for the suregrip? Not sure what the code of the stripes is, but I want to make sure what I'm seeing is right for my A36 Package: 3 white and 1 Orange.
3. I also found on the back of the housing the large yellow B for 69 B-body, and a white circle and it's either a slash or an X. I can't make out if it's an X inside the circle or just a slash due to wear, but it seems it's just a slash as it's pretty worn to see the other slash making an X. Searches on this just seem to confuse me more. I found one claim that non-sure grip cars had a circle with a slash, and sure grip cars were circle and an X. He was refering to 68 axles. Another 69 Charger I had was a 3.23 open and it had the yellow B and a circle and an X clearly visible. Original axle as denoted by the 3 digit axle code, dates, and history of the car. So what gives? Circle and Slash means sure grip, Circle and X means non-sure grip in 69? Did they change that year to year?
Thanks Guys. I appreciate the input.
Cheers
Re: 69 8.75 Axle markings, codes, etc [Re: 68RRFlyer] #1123207
11/28/11 02:05 PM
11/28/11 02:05 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Dave, this look familar? These are from my former '68..
Troy
Houston Mopar Connection Club
Re: 69 8.75 Axle markings, codes, etc [Re: hemi68charger] #1123208
11/28/11 02:07 PM
11/28/11 02:07 PM
Houston, Tx
Houston, Tx
The carrier...
Troy
Re: 69 8.75 Axle markings, codes, etc [Re: hemi68charger] #1123209
11/28/11 02:13 PM
11/28/11 02:13 PM
Houston, Tx
Houston, Tx
I have a parts book for '69, so we could probably find the 3-digit number for the axle tube if someone doesn't chime in earlier.
Troy
Re: 69 8.75 Axle markings, codes, etc [Re: hemi68charger] #1123210
11/28/11 02:25 PM
11/28/11 02:25 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The white stripe is for ONE and the orange for 1/2. So for 3.55 you should have 3 white stripes and one orange - just like you have
Re: 69 8.75 Axle markings, codes, etc [Re: Morty426] #1123211
11/28/11 03:29 PM
11/28/11 03:29 PM
DFW
DFW
Thanks Morty for the corroboration, and I did find that is the correct 3 digit broadcast sheet code for my axle.
Troy, although I appreciate the input, I know what they look like, and that's not what I was asking. Your axle is the same as on Dan's 68 I restored. 242 code, open 3.23. The circle and the X or slash is the issue I was asking about since I am seeing different opinions on the subject.
So two of the three solved: BS code and the three whites and one orange. What's the verdict on the circle and slash or X?
Cheers
Re: 69 8.75 Axle markings, codes, etc [Re: 68RRFlyer] #1123212
11/28/11 04:12 PM
11/28/11 04:12 PM
Houston, Tx
Houston, Tx
Cheers
I believe the circle with the "X" or slash was the inspection marker that gearlube was installed... no?
Charger Board thread by yourself on 8.75 markings
Troy
Re: 69 8.75 Axle markings, codes, etc [Re: hemi68charger] #1123213
11/28/11 04:30 PM
11/28/11 04:30 PM
DFW
DFW
Troy, yeah, I looked that over before I posted since Maxwell had some good info. But he even said there was debate about it and I wanted to see what the consesus was about them and if anyone had anymore insight. Mine looks to be a circle and a slash. I originally thought it meant the axle was serviced too, but I'd say that was what the orange blop on the filler plug is for (white for non-sure grip). Someone posted on the DC forum about the suregrip getting the (X) and a non-sure grip getting a slash (/). Well mine is a sure grip and has a slash, the other 69 I had was a circle and an X and was an open 3.23. Crikey! Enough to make your head hurt. I'm just going to replicate and document what I see but it'd be nice to know what the heck it means.
Cheers
