my plan is to freshen up a 360 i have from motor home and put it into a 66 dart. trying not to spend a lot and obviously won't be a hi-po motor but i would like it to be fun to drive.
here is what i have so far:
- 74 360 w/ 74K miles
- 340 HP manifolds
- 360 heads from '90 LA360 roller motor (to be rebuilt and swapped out for whats currently on it)
- transmission will be rebuild a904 with stock converter (i got this from a parts car).
here is what need advise on:
- what cam (and should i replace valve springs?)
- what intake (single or dual plane) *i have a 340 oem cast iron intake for spread bore)
- should i look for a better set of heads?
my plan is to do this on the cheap with exception of the 340 HP manifolds which cost a bundle but no other options for the early a's
thanks in advance.
