Dart ride height adjuster broke? #1122535
11/27/11 06:44 PM
11/27/11 06:44 PM
N.E. Ohio
SuperD Offline OP
SuperD  Offline OP
N.E. Ohio
Ok I was backing my 71 swinger out of the drive and suddenly a loud bang and my front end dropped down. I looked and saw that the ride adjuster pulled off of the bolt that passes through the lower control arm. Does anyone know if this is hard to fix or what the technical term is for the part that im describing? Ive never ran into this before and am kind of stumped on what to do as the torsion bar looks fine. help please
Re: Dart ride height adjuster broke? [Re: SuperD] #1122536
11/27/11 07:05 PM
11/27/11 07:05 PM
the bolt fine threads gave out & pulled thru the block? Prob a bolt/block that's been taken apart/reassembled many times which actually is rare. I'd get another block/bolt & put it back together & maybe get a distance from the other side lower control arm to the subframe & duplicate that to keep the alignment intact
Re: Dart ride height adjuster broke? [Re: SuperD] #1122537
11/27/11 07:09 PM
11/27/11 07:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Very strange... that usually only happens when the
torsion bar breaks... you can get new parts from Mancini's
(bolt and block)... check to see if it just slid off
the arm... but it shouldnt have because the block has
2 grooves that the arm lays in... if nothing is broke
you can back the bolt out and reinstall it
EDIT
I read a little closer and you said it pulled the
bolt through.... new parts are needed(Mancini's)
Re: Dart ride height adjuster broke? [Re: SuperD] #1122538
11/27/11 07:19 PM
11/27/11 07:19 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Post a pic of the bolt. TO me thats really odd. Wondering if the bolt isnt correct.
Re: Dart ride height adjuster broke? [Re: NTOLERANCE] #1122539
11/27/11 07:34 PM
11/27/11 07:34 PM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
strip out no bigeeeeeeeee get new block and bolt as said.You mush have a lot of preload on that bar.
Re: Dart ride height adjuster broke? [Re: SuperD] #1122540
11/27/11 07:40 PM
11/27/11 07:40 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Is the torsion bar mount rusted under the car?
Re: Dart ride height adjuster broke? [Re: Challenger 1] #1122541
11/27/11 07:49 PM
11/27/11 07:49 PM
when you go back together keep the block squared not tilted on the bottom grooves and when the round nub first starts to contact the recess move the block/bolt slightly so they are still "square/in line" for the first couple of turns then crank it up & having the front end off the ground till you get close to the final height makes it go alot easier (on you & the parts)
Re: Dart ride height adjuster broke? [Re: Challenger 1] #1122542
11/27/11 07:54 PM
11/27/11 07:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what I first thought... the trans cross over
mount tore out
