Chain steering system drop #1122275
11/27/11 11:06 AM
11/27/11 11:06 AM
Auburn, Indiana
The Duster Offline OP
Auburn, Indiana
Saw this car on a TV show this morning and thought this was a neat way to fix steering angle / placement issues.
Re: Chain steering system drop [Re: The Duster] #1122276
11/27/11 11:15 AM
11/27/11 11:15 AM
moparx Offline
moparx  Offline
i believe there is a couple of outfits making those. i know one has a cover and is "lubed for life". i havent inspected a unit up close to verify the quality however.
Re: Chain steering system drop [Re: moparx] #1122277
11/27/11 12:13 PM
11/27/11 12:13 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Seen a few of them now.
The enclosed type was used on Church's VanGo.
Re: Chain steering system drop [Re: RodStRace] #1122278
11/27/11 08:37 PM
11/27/11 08:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Don't think I'd feel very comfortable with an open gear setup under an open hood. Wouldn't take a very big stone to get caught between the gear and the chain to lock the steering, I think. Might feel a little better about a covered one, but I think that would have to be on my annual check list. Gene
Re: Chain steering system drop [Re: poorboy] #1122279
11/28/11 05:17 PM
11/28/11 05:17 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I agree with Gene, my first thought was no way I would run around with that open like that. one little stone would ruin your day fast
now a closed setup would be OK but they cost over $500.00 to buy one
Re: Chain steering system drop [Re: Mopar Ron] #1122280
12/01/11 12:10 PM
12/01/11 12:10 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Then go with the open one and put a cover over it. I would use a screen mash or expanded meatl type of material to be able to show off the unit. Hot rodding and street rodding to me means building not buying. That's how it all started. Just one guys opinion.
By the way I LOVE the unit picturede in the first post..
I have mechanical Aptitude.
I can screw up anything.
Re: Chain steering system drop [Re: bboogieart] #1122281
12/02/11 12:16 AM
12/02/11 12:16 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I don't really have a problem with the design, least what I can see of it
I do have an issue with the sprockets being open to stuff getting in there. Any enclosure would have to be solid, even a fine screen would let in enough dirt & sand to make a mess out of the chain, gears, and bearings in short order. Anything that could get between the chain and the sprocket can jam up the steering. You can not exert enough force on a steering wheel to even over come a small twig if it got between the chain and sprocket. I've had the experience of a locked up steering! Even a second or two will shorten your life by 10 years because of the shear terror of not being able to turn the steering wheel. That short experience was enough to ensure that I don't ever want to have that experience again in my life. Expanded metal would only be slightly better then having nothing. Gene
Re: Chain steering system drop [Re: poorboy] #1122282
12/02/11 08:09 PM
12/02/11 08:09 PM
dogdays Offline
dogdays  Offline
Well look at some of the farm equipment stuff, they steer with hydraulic cylinders controlled by a valve hooked to the steering wheel. This looks a lot better than that.
First thing I thought of was "quick change". How about a rudimentary two speed transmission using a dog clutch for more ratio in the parking lot and less on the highway?
Second thing I thought about was steering "quickener" gearboxes used in street stock type dirt track cars. they look like they probably have chains inside.
The whole thing is actually funny after you get over the shock. In a real way it's art. It gets a response from the viewer.
Later,
R.
Re: Chain steering system drop [Re: dogdays] #1122283
12/03/11 08:13 PM
12/03/11 08:13 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Those hydeaulic operated systems do not go 70 miles an hour down the highway and do the job intended.
Speaking of intended job. The picture in the origanal post does not look like a daily driver to me and more of a show car. So for show it looks realy cool. Guess it depends on your usage. It seems there are several options for an enclosed chain. This might even be one that has been uncovered. Don't newer cars use electronics? ie sensors and servos, just like on the gas pedal. If they aren't yet I'm guessing it won't be long. Now that scares me!
Re: Chain steering system drop [Re: bboogieart] #1122284
12/04/11 01:12 AM
12/04/11 01:12 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I believe that chain drive was featured on a Cadillac Edition of Hot Rod TV where the chain drive was in a 32 Ford with a Cadillac engine in it.
Re: Chain steering system drop [Re: MuuMuu101] #1122285
12/04/11 12:13 PM
12/04/11 12:13 PM
Auburn, Indiana
Auburn, Indiana
Here is the link for the full car info and pics.
http://www.streetrodderweb.com/features/1008sr_1932_ford_highboy_roadster/viewall.html
Re: Chain steering system drop [Re: The Duster] #1122286
12/04/11 02:01 PM
12/04/11 02:01 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanx for the link. That is one well thought show car. Very nice.
I get it about the debri hazzard but like I said I doubt it gets driven much, if at all. Great show case for talent though.
