Big block into early 65 Cuda ??
#1122111
11/26/11 11:17 PM
11/26/11 11:17 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
So I hate headers but lately I have been thinking about throwing one of my spare big blocks in my spare 65 cuda. I know the factory never put them in so there are no manifolds made for this. My question is what (if any) exhaust manifolds will work for this swap?
Re: Big block into early 65 Cuda ??
[Re: HotRodDave]
#1122112
11/26/11 11:19 PM
11/26/11 11:19 PM
HotRodDave
Kalispell Mt.
and what about motor mounts?
[Re: GO_Fish]
#1122115
11/27/11 12:54 AM
11/27/11 12:54 AM
HotRodDave
Kalispell Mt.
No exhaust manifolds means I will not put a BB in it.
Now....
Has any one ever put a BB in an early A with ex manifolds?
[Re: HotRodDave]
#1122116
11/27/11 01:14 AM
11/27/11 01:14 AM
RapidRobert
68-70 B body HP ex manifolds will fit w a B (383/400) IF manual steering. I'm doing one as we speak. reportedly max wedge manifolds will also & I saw a pic of an early A with MW manis and a 440. In rare cases a 727 will fit with only flattening the pinchweld on the firewall downward slope but most need a section of it to be cut/raised. Streetmaster mts (if still in business). regular center sump BB pan. Hooker fenderwell super comps 5215 or 5205 (one is 1&7/8, one is 2" forget which is which) will fit on the dr side and 1 or 2 tubes on pass side need reworked. Use as much alum items to reduce the front heavyness, water pump/housing/M/C/intake/rad/wheels/(fiberglass) bumper. www.speedwaymotors.com has 1&7/8 ex tubing extra bends for cheap. There's more varation/stackup of tolerances on early A's than any group I've ever seen & reportedly even an RB has in several cases fit w the above mentioned 68-70 manis.
[Re: dogdays]
#1122118
11/27/11 01:29 PM
11/27/11 01:29 PM
HotRodDave
Kalispell Mt.
I will trade you a 440 motor home engine, a good 413, a good 383 with 906 heads, 69 440HP bare block, a 71 230 casting 400 complete std bore engine, and a set of BB HP manifolds and you give me a 408 SB and 340 HP manifolds, so we have a deal? I have been trying to sell my BB stuff to buy SB stuff but no one is biting. I can re-ring and bearing the 440 throw some 516 heads on with a little port work and make more TQ and HP than a bare bones 408. I am a dyed in the wool SB guy but for the budget on this car I can go high 11s real cheap and easy with a 440, any faster and it needs a roll bar and I don't want one. Beleive me I would rather do a stroker SB but I don't have a ton of parts sitting around for it. I would have to buy pistons and crank and pay for balancing, rings, bearings, gaskets, and boreing at a minimum. The 440 can just get new gaskets rings and bearing and be a good running motor. I can build a good trans with my spare parts for either motor, I have a couple 8.75 a body rears, either motor will need new exhaust because the car was a slant six, I want to ditch the funky drive shaft so either motor will need a different shaft. If I had the $$$ to build the 408 then why not use that $$$ to put the 413 crank in the 400? So unless someone wants to buy all my BB stuff and leave enough $$$ to build a stroker SB then the BB will probably end up in the car. Besides, I have never really had a BB car so mabey I should take a sip of the BB cool-aid ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: slantzilla]
#1122122
11/27/11 04:22 PM
11/27/11 04:22 PM
Once you've gone BB you'll wonder why it took so long!
The only smallblock I have is the 360 in my truck and that's just because it was there and has plenty of power. Too much hassle to swap.
BB's are dirt cheap to build on a budget if you're staying under 500 hp. and start with a good core.
As far as fitment into an early A, I'd go with the low deck block to start with.
[Re: Kern Dog]
#1122125
11/27/11 08:17 PM
11/27/11 08:17 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Somewhere I have pics of an early valiant with an early hemi.
No headders, log manifolds.
I'd have to power up the cold windows 98 computer (its in pieces) to find them.
[Re: HotRodDave]
#1122126
11/27/11 09:05 PM
11/27/11 09:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I can build up a 396ci if you want to swap that stuff ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1122127
11/27/11 09:07 PM
11/27/11 09:07 PM
HotRodDave
Kalispell Mt.
PM me if your serious ![](/ubbthreads/images/graemlins/thumbs.gif)
