vacumm guage #1121776
11/26/11 04:56 PM
11/26/11 04:56 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
I adjusted the timing with a vacumm guage as was recommended. The timing mark is about 2 inches of the mark but it starts and idles good. My question is the vacumm gauge goes from 19 to 21 rapidly. When you rev it up it smooth out.
What do I check now?
This a stock 273 commando in my 65 Barracuda Formula S.
Thanks for your help.
Re: vacumm guage [Re: Tadams] #1121777
11/26/11 05:00 PM
11/26/11 05:00 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
at what rpm did you set the vacuum? I usually tried it at about 1000 and then retarded it 2* to keep from detonation or preignition. TIm
Re: vacumm guage [Re: Tadams] #1121778
11/26/11 05:35 PM
11/26/11 05:35 PM
The timing mark is about 2 inches of the mark My question is the vacumm gauge goes from 19 to 21 rapidly.What do I check now?
(1) clarify that (2) there's a prob somewhere (if not a radical cam). (3) If you experiment w idle mixture/speed can you get it to get steadier?. what idle speed and is that Formula S cam a lumpy one EDIT (re)read it & 19-21 would have to be a smooth cam. I'd do a compression/leakdown tests for starters after idle mixture and short each cyl to ground (cyl balance) & note what the needle does. Sounds like one cyl (or more) is a fair amt weaker than the others/not pulling it's load when it fires making it dip to 19 for that split second that it is firing
Re: vacumm guage [Re: Tadams] #1121779
11/26/11 06:09 PM
11/26/11 06:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On your 273 is that a mech cam... check your lash
adjustment
Re: vacumm guage [Re: MR_P_BODY] #1121780
11/26/11 06:47 PM
11/26/11 06:47 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Thanks every one for your help. It is a stock engine and has a stock cam.I think with the 4 barrell this car should have dome pistons and I think the cam is a little different from the regular engine. Idle speed was 800 RPM and the high the rpm the smoother it was. I'll adjust the valves next week and see if that helps. The carb was just rebuilt and I think is set properly.
Re: vacumm guage [Re: Tadams] #1121781
11/26/11 08:53 PM
11/26/11 08:53 PM
scratchnfotraction Offline
vac gauge fluctuating bouncing could be a
bad valve/weak cyl.
rockers out of adjustment
timeing chain sloppy
vac leak
for starters,a comp check and leak down wet and dry are in order.
snake oil test....
hold a dollor bill at the tail pipe and see if it sux it in then pops it back out while watching the vac gauge bounce in time with the doller poping
Re: vacumm guage [Re: scratchnfotraction] #1121782
11/26/11 09:51 PM
11/26/11 09:51 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Thanks for the info. I'll try that next week. Family coming to complete celebrating Thanksgiving and church in the morning so no car work tomorrow.
Re: vacumm guage [Re: Tadams] #1121783
11/26/11 10:04 PM
11/26/11 10:04 PM
Holler how it comes out
Re: vacumm guage [Re: RapidRobert] #1121784
11/26/11 10:59 PM
11/26/11 10:59 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
2" off,,, are you useing # 1 plug or did you goof up and use #2 plug to hook the timing light up to???
I am truckless..
Re: vacumm guage [Re: 340SHORTY] #1121785
11/27/11 12:43 AM
11/27/11 12:43 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
And where did you hook up the vacuum gauge?
Re: vacumm guage [Re: earlybee] #1121786
11/27/11 01:11 AM
11/27/11 01:11 AM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
I used the 1 plug and hooked the guage to the manifold. When using the timing light you can see the mark starting to come into view about 2 inches before the line you should set it by. I had set it by the light and when you put it in gear it would die. Someone said to set it by the vacumm guage and adjust the distributor to get the highest setting. Thats what I did and now it starts good and I can put it in gear and it idles as it should. It takes the gas well and the engine is very smooth, not shaking like it would if it had a bad miss or something. I hope what I have said makes since. Thanks for your help.
Re: vacumm guage [Re: Tadams] #1121787
11/27/11 01:41 AM
11/27/11 01:41 AM
2" on the dampener is ~32 deg and that is just to the left edge of the tab? or is that in to the zero in the middle of the tab. Something still ain't right EDIT I suspect the too high initial is possibly causing the unsteady needle EDIT on the initial you got max vac in drive then backed off 1 in hg all the while reducing the idle speed correct?
Re: vacumm guage [Re: RapidRobert] #1121788
11/27/11 10:23 AM
11/27/11 10:23 AM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Hi Robert, The more I turn the timing back to where it would actually show as normal the more the guage bounces and it goes further than 19 to 21, such as 17 to 23 or so. I know the distrubuter was rebuilt before I got the car. Could it be a tooth off when it was put back in the engine? Just a thought. The idle speed was turned down.
Thanks so much for your help. It is drivable now where as before it would die when I put it in gear. This is an improvement though not correct, it is better than before.
My wife said I need to make a new friend locally who works on cars, sounds like a plan.
Re: vacumm guage [Re: Tadams] #1121789
11/27/11 10:51 AM
11/27/11 10:51 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
sound advice but make sure you stay involved (hands-on) join a local mopar club. for someone that isn't that mechanically inclined, all the advice (while usually good) can make your head spin!
Re: vacumm guage [Re: mikemee1331] #1121790
11/27/11 12:03 PM
11/27/11 12:03 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Hi Mike,
Im learning, for sure.
Re: vacumm guage [Re: Tadams] #1121791
11/27/11 12:35 PM
11/27/11 12:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
recommendation - get yourself a FSM (field source manual) or a Chilton's/Hayes manual for your car. readily available on the 'net and don't be shy to ask questions!
Re: vacumm guage [Re: mikemee1331] #1121792
11/27/11 01:43 PM
11/27/11 01:43 PM
pull #1 plug and bring #1 piston up to TDC and check to see if the timeing mark is correct.
it may have a slip damper ring and not want to time with the marks
while you have the plug out,piston TDC,check to see were the rotor is pointing in the cap to rule out a jumped chain/tooth off.
Re: vacumm guage [Re: Tadams] #1121793
11/27/11 01:54 PM
11/27/11 01:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hi Mike,
Dont get too hung up on the fact that the vac gauge
jumps some at lower rpm... the slower the rpm it
has more time to see the pulse... at higher rpm they
are blended together.... plus the LSA on that cam
is tighter which has more over lap and more over lap
has pulses
Re: vacumm guage [Re: MR_P_BODY] #1121794
11/27/11 02:41 PM
11/27/11 02:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Hi Mike,
has pulses
BINGO
Re: vacumm guage [Re: mikemee1331] #1121795
11/27/11 07:23 PM
11/27/11 07:23 PM
I'd recheck all the basics: adj valves (.013 in .021" ex). Timing chain (rockover). slipped dampener w the piston stop tool. marks at 10BTDC #1 compression & time dist at that initial (which is stock for all 4bbl and 2bbl w auto and or power pack). 2bbl WO them is 5. Plus compression test (leakdown too if you have a gauge setup)
