Re: torqueflite issues?
[Re: lewtot184]
#1121768
11/26/11 06:42 PM
11/26/11 06:42 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Aeration is caused by an overfull condition or the pump sucking air...in some rare cases an internal leak will stir up the fluid enough to cause aeration. The problem is, aeration will cause whining, buzzing, etc. and so will an internal leak.
Whining/buzzing in the absence of aeration can be caused by a rapidly cycling pressure regulator valve, this has been a TF problem since day one...more of a nuisance than a real problem. A fluid/filter change might help.
[Re: John_Kunkel]
#1121769
11/26/11 06:58 PM
11/26/11 06:58 PM
Posts: 3,916 usa
lewtot184
usa
john, i was hoping you'd chime in. the tranny seems to shift alright but noise is fairly bad when cold. where is the pressure regulator valve? what fluid would you recommend? how do you chase an internal leak? would an internal leak be a valve body issue? i'm not a "torqueflite guy" but i can pull maintenace on'em.
[Re: lewtot184]
#1121770
11/26/11 09:06 PM
11/26/11 09:06 PM
John_Kunkel
Rio Linda, CA
The factory recommended cure for the noise is to replace the valve body....I would rather just live with it.
For fluid go with Dexron or Type F.
