Re: LIBERTYS GEARS
[Re: komninon]
#1121723
11/26/11 02:36 PM
11/26/11 02:36 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
if your having it faceplated, their right. your wife should be able to powershift it after that.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
Re: LIBERTYS GEARS
[Re: fourgearsavoy]
#1121727
11/27/11 03:45 AM
11/27/11 03:45 AM
Posts: 151 Canada BC
Steve Barton
Canada BC
they are not going to faceplated. the do not recomend it for street driving.
Now I have to disagree with that statement,I think that a face-plated transmission will last much longer and and shift easier on the street. I have a face-plated Richmond 5-speed in my car and it's a much better transmission for street/strip than a my older Pro-shift 833's The face-plates actually interlock with each other which prevents the transmission from popping out of gear on decell like a Pro-shift unit can do after it starts to wear out. Gus
x2 on that, my 833 is pro shifted on sec gear and face plated on 3rd and 4th. The only gear that wears out on the street is sec gear, and the only gear I cant power shift. Liberty now makes a face plated sec gear for the 833s. I will be putting one in this winter.
Re: LIBERTYS GEARS
[Re: Steve Barton]
#1121728
11/27/11 12:42 PM
11/27/11 12:42 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'm not super familiar with what Liberty does, but I thought I read somewhere that they don't faceplate the TKO, they do something with the syncros, or swap them out to better ones...something about taking the bronze ones out and going with Kevlar syncros?
**Photobucket sucks**
Re: LIBERTYS GEARS
[Re: 70Cuda383]
#1121729
11/27/11 12:43 PM
11/27/11 12:43 PM
70Cuda383
Marysville, O-H-I-O
nevermind...just went back to their website, they offer 2 services for the TKO, one of which IS faceplating.
Re: LIBERTYS GEARS
[Re: LAR_414]
#1121733
11/28/11 01:16 PM
11/28/11 01:16 PM
Steve Barton
Canada BC
Faceplating with an A-833.....how are the manners on the street? Will it Clunk or anything, driving normally on the street? What about downshifting? Do you have to match speed? Double clutch? Noise when engaging gears without a stop ring?
Noisy, yes they clunk going into gear, down shift easy but still clunk and wile you are driving, if you excel and then de-cell it will clunk. My car is a 71 Valiant small block but it has a 700 lift cam, so if I am cruising at low rpm it will buck back and forth so I cruise in sec gear and keep my rpm,s up. keep in mind for me its all about having the best trany for the track and still mopar. I am pushing 650 Hp to the rear tires and just into the 9s in the 1/4 so a little clunking on the street is just fine with me.
Re: LIBERTYS GEARS
[Re: johnmilner]
#1121737
05/15/14 10:17 PM
05/15/14 10:17 PM
Posts: 1,505 TN
SCATPACK 1
TN
What is Faceplating... Look at the trans picture above. It has all of the gears conversions in it. 3rd and 4th are face plated. See the lugs that are star shaped on the end of the gears. 2nd gear has the liberty conversion on it and first has been slick shifted. (removed every other tooth) Look on the Liberty site for a comparison too.
Old Geezer Racing
Re: LIBERTYS GEARS
[Re: 68 HEMI GTS]
#1121738
05/16/14 01:45 AM
05/16/14 01:45 AM
Posts: 409 Texas
mprhound
Texas
yep they clunk. you can downshift without double clutching the faceplate, just takes a little driving time to figure it out. the face plate is really a good way to go on a street/strip car. i would have loved to have a faceplated 2nd. guess they can syn first gear also, thats the only way to go. i always hated rolling up to a light then having it turn green while the car was still rolling without the syncro on first.
my dart was just a little to heavy for a chrysler box, i might piece together another liberty for my RR.
how many passes before the teeth let loose? is this common? or just to much hp and weight? the reason I ask is that I was thinking of this route for my challenger 3680 pounds with a new 505 stroker in it, for drag week. the 18 spline held up fine last year with the 440.
