More ??? on 67 Fender tag. Hidden #'s???? #1121712
11/26/11 01:57 PM
11/26/11 01:57 PM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
I stripped the tag and found # stamped in. Might be hard to see but its 34A. Anyone know what they are???
Re: More ??? on 67 Fender tag. Hidden #'s???? [Re: Russ_Davis] #1121713
11/26/11 02:09 PM
11/26/11 02:09 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Inspectors mark
Re: More ??? on 67 Fender tag. Hidden #'s???? [Re: 1_WILD_RT] #1121714
11/26/11 03:55 PM
11/26/11 03:55 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Inspectors mark
Typical stampings from the STL plant. The impressed stampings were done pre-paint so they may be related to the BIW assembly, not unlike the Gate-Base numbers on a LR tag, and may not be an inspectors stamp. (They are usually very hard to read making it difficult to compile a data base showing consistency or correlation. Research continues )
The punch through is also typical of STL and probably is an inspectors stamp of some sort.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
