popping out exhaust on decel #1121240
11/25/11 07:00 PM
11/25/11 07:00 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
what causes it? could it just be my stupid staight pipe extremely loud exhaust? engine didnt do it in the challenger but that car had H pipe and full exhaust
Re: popping out exhaust on decel [Re: sixpackgut] #1121241
11/25/11 07:07 PM
11/25/11 07:07 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
exhaust leak could do that. brad
Re: popping out exhaust on decel [Re: sixpackgut] #1121242
11/25/11 07:41 PM
11/25/11 07:41 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I had a header gasket do that
Re: popping out exhaust on decel [Re: BLONDE BARRACUDA] #1121243
11/25/11 08:03 PM
11/25/11 08:03 PM
It is from a header leak. either at the flange or at your collector merger.Chek your header bolts or youll need to change your gasket or just run straight hi-temp silicone of the flange to head.
Re: popping out exhaust on decel #1121244
11/25/11 09:56 PM
11/25/11 09:56 PM
Guitar Jones Offline
It could also be lean. Going from a full exhaust to open exhaust you'll need to richen it up.
Re: popping out exhaust on decel [Re: Guitar Jones] #1121245
11/25/11 10:55 PM
11/25/11 10:55 PM
Not on decel only on accel.
Re: popping out exhaust on decel #1121246
11/25/11 11:01 PM
11/25/11 11:01 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
check valve lash
1.39 9.85 - 137 mph
Re: popping out exhaust on decel [Re: Guitar Jones] #1121247
11/25/11 11:06 PM
11/25/11 11:06 PM
Charleston
Charleston
i was thinking it was rich so i jetted down the center carb. didnt make a difference.
i havent noticed any exhaust leaks. may need to put washers under the header bolts, they may be bottoming out
Re: popping out exhaust on decel [Re: sixpackgut] #1121248
11/25/11 11:23 PM
11/25/11 11:23 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
A cam with a lot of overlap & a short header
Re: popping out exhaust on decel [Re: emarine01] #1121249
11/25/11 11:44 PM
11/25/11 11:44 PM
If you were lean,you'd pop out the carb not exhaust.
Re: popping out exhaust on decel #1121250
11/26/11 08:46 AM
11/26/11 08:46 AM
Not necessarily so. It could be real close. I know it doesn't seem like that but with the rpm's up there and the throttle closed they go lean pretty quickly. Fatten it up from where it was originally and see if that doesn't take care of it.
Re: popping out exhaust on decel [Re: a493demon] #1121251
11/26/11 10:17 AM
11/26/11 10:17 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Cracked header tube or gasket. Believe me just alittle crack is enough to make the popping noise.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: popping out exhaust on decel [Re: Guitar Jones] #1121252
11/26/11 11:21 AM
11/26/11 11:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Popping in the exhaust is from fuel igniting in the exhaust system. Briggs and Straton goes so far as to electrically close the main jet on shut-off to prevent backfire in the exhaust on shut-down. Eliminate any air leaks in the exhaust system and eliminate as much fuel as possible. If it doesn't have oxygen and fuel it won't ignite.
Doug
Re: popping out exhaust on decel [Re: dvw] #1121253
11/26/11 11:42 AM
11/26/11 11:42 AM
Yeah when you shut it off, not just on deccel. Been there done that, take it or leave it. Not looking to argue with anyone, just stating my experience, YMMV.
Re: popping out exhaust on decel [Re: dvw] #1121254
11/26/11 11:50 AM
11/26/11 11:50 AM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
Doug
I had the same problem. I leaned out my carb and blocked off my intermediate circuit, and all the popping went away. The popping is from unburnt fuel in the exhaust igniting.
Re: popping out exhaust on decel [Re: sixpackgut] #1121255
11/26/11 12:31 PM
11/26/11 12:31 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
Two things or both come to mind.
1. exhaust leak... fresh oxygen mixing with unburnt fuel.
2. Rich idle/ transition circuit...When throttle plates are slamed closed, engine braking occurs. very high intake vaccuum.lots of fuel pulled from idle circuit. not much oxygen however.
this creates a very rich afr. may not fully burn in combustion chamber. unburnt fuel enters exhaust. Too much unburnt fuel can ignite on hot parts of exhaust system. add oxygen from leak and eaiser to ignite.
Re: popping out exhaust on decel [Re: ToddP] #1121256
11/26/11 04:05 PM
11/26/11 04:05 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Last season my car was pretty bad, which wasn't an issue for me,,, but I changed carbs and it was done.
Usually its an exhaust hole.
Re: popping out exhaust on decel [Re: sixpackgut] #1121257
11/27/11 11:09 AM
11/27/11 11:09 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm guessing your car does not have power brakes?
Re: popping out exhaust on decel [Re: Challenger 1] #1121258
11/27/11 01:36 PM
11/27/11 01:36 PM
Charleston
Charleston
no why?
i found a couple header bolts a little loose. i need to bump the jet back up on the center carb. another thing is i never really drove around with the bug catcher on the motor in the challenger. so if i'm goin 100mph and let off, there could be alot of air doing weird stuff in there
Re: popping out exhaust on decel [Re: sixpackgut] #1121259
11/27/11 02:47 PM
11/27/11 02:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
no why?
My 74 started popping on decell earlier this summer, the power brake booster was leaking. Also caused a erratic idle. Replaced it and all is normal again on decell.
