Here is the Slant 6 that I would like to have #1121192
11/25/11 04:00 PM
11/25/11 04:00 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
I don't remember seeing anything about this car, but it is pretty cool. Seems a lot of Comp Eliminator guys seem to think outside of the box on what they run. Kinda neat really.
Re: Here is the Slant 6 that I would like to have [Re: Scamp451] #1121193
11/25/11 04:01 PM
11/25/11 04:01 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
... another.
Re: Here is the Slant 6 that I would like to have [Re: Scamp451] #1121194
11/25/11 04:23 PM
11/25/11 04:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
oh boy, don't let slantzilla see this
Re: Here is the Slant 6 that I would like to have [Re: Scamp451] #1121195
11/25/11 05:04 PM
11/25/11 05:04 PM
Guitar Jones Offline
What the he!! is that thing?!?
Re: Here is the Slant 6 that I would like to have [Re: Scamp451] #1121196
11/25/11 06:03 PM
11/25/11 06:03 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
There used to be quite a few 6-cyl. cars in Comp back in the day. With today's technology & wish I had the bucks to build a wild /6. I know of a trick 4-cyl. Ford combo using quite a few stock parts for a 400 cu. ins. I'm thinking if trying when I sell off an iold racecar. My guess on it would be 300-350hp n/a for a really cool/trick street motor.
Re: Here is the Slant 6 that I would like to have [Re: Guitar Jones] #1121197
11/25/11 06:10 PM
11/25/11 06:10 PM
PA
moparacer Online content
moparacer  Online Content
PA
Half a hemi....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Here is the Slant 6 that I would like to have [Re: hemicop] #1121198
11/25/11 06:15 PM
11/25/11 06:15 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Anyone notice the cross-flow head? And the plugs on the wrong side? Not sure what that is---is it a Jeep engine? I see the belt or cam driven distributor too.
Outcast Dodge guy.
Re: Here is the Slant 6 that I would like to have [Re: moparacer] #1121199
11/25/11 06:16 PM
11/25/11 06:16 PM
Half a hemi....
Looks more like two of those 4 cylinders welded together with a cylinder removed from each end or one cut in half with the center 2 cylinders from another welded together. It ain't no regular slant 6 that's for sure!
Re: Here is the Slant 6 that I would like to have [Re: Scamp451] #1121200
11/25/11 06:30 PM
11/25/11 06:30 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
my guess its one of those Aussie HEMI 6 bangers..
I was looking around and the Australian slant and the straight inline hemi 6 do not have cross flow heads...thats a weird one plus the engine is slanted the other way unless the photo is reversed..
Re: Here is the Slant 6 that I would like to have [Re: smokinwoody] #1121201
11/25/11 06:39 PM
11/25/11 06:39 PM
If you look close it looks to be aluminum and it has Mopar in blue lettering like the 4 banger half a small block has. There are versions for wedge heads and the P5 head which that appears to be. Just a guess though.
Oops, I meant the blue freeze plugs...
Re: Here is the Slant 6 that I would like to have [Re: smokinwoody] #1121202
11/25/11 06:39 PM
11/25/11 06:39 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
nah! ain't one of our Hemi 6's, they weren't crossflow or slant.
Re: Here is the Slant 6 that I would like to have [Re: rebel] #1121203
11/25/11 06:45 PM
11/25/11 06:45 PM
Plus it's slanted the other way like the 4 lunger is.
Re: Here is the Slant 6 that I would like to have [Re: Guitar Jones] #1121204
11/25/11 06:50 PM
11/25/11 06:50 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
a few years back, I saw a rear engined dragster that had a big Ford straight 6...I looked closer and here he had Cleveland heads...they had cut the heads and welded them together to make a straight 6 and then machined them...it looked so factory..
you maybe right here that they took two heads to make the one...would that picture be reversed? as far as the slant goes or is that another trick engineering job ...
Re: Here is the Slant 6 that I would like to have [Re: smokinwoody] #1121205
11/25/11 06:54 PM
11/25/11 06:54 PM
It's not reversed, the lettering isn't. That was the first thing I looked for but I can read upside down in a mirror too so...
Re: Here is the Slant 6 that I would like to have [Re: Guitar Jones] #1121206
11/25/11 07:03 PM
11/25/11 07:03 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I noticed the slant to be reversed too. Checked the lettering to see if it to was reversed, nope.
Re: Here is the Slant 6 that I would like to have [Re: Scamp451] #1121207
11/25/11 07:20 PM
11/25/11 07:20 PM
Goat Rodeo
drago Offline
drago  Offline
Goat Rodeo
Internet search -
"MOPAR powered Inline 6/P5 Hemi I/AA Comp Eliminator entry. The engine is an engineering marvel that started life as 2 mopar 4 cyl USAC sprint car blocks and 2 mopar P5 Hemi heads in his 2 car garage. John cut, welded together and partially machined both the heads and block with lazer like accuracy using common tools and without cnc equipment. Since his engine is essentially a unicorn John had to design, engineer and fabricate EVERYTHING from rocker stands, oilpan, belt drive, intake manifold to the simplist of brackets because these parts just don't exist."
Re: Here is the Slant 6 that I would like to have [Re: Sport440] #1121208
11/25/11 07:21 PM
11/25/11 07:21 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Actually, most all of you figured it out. I think it is really neat, but this guy went through a great deal of pain and coin to do this. My question is, why stop at 6 cylinders, make it an in-line 8 instead of throwing away a couple cylinders and chopping a 1/4 off 2 heads to get 6? Either way, it truly is a wicked engineering effort. Won best engineered car at a National event last year.
More redigested info:
http://www.yellowbullet.com/forum/showthread.php?t=289099
Re: Here is the Slant 6 that I would like to have [Re: Scamp451] #1121209
11/25/11 10:10 PM
11/25/11 10:10 PM
That my friends is the essence of hot rodding and a labor of love. More power to him and I hope he conquers the world with it!!
