Re: OK season's over time for "DON'T ASK ME HOW I KNOW'
[Re: Super Scamp]
#1120926
11/26/11 11:17 AM
11/26/11 11:17 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Going to a race 300 miles away fully loaded, all gased up food in frig,everything you can think of in motorhome and trailer and when you get to the track and get all setup (Thursday night). Went to go get a cold beer Yep you know it !!!! left it in the garage 3 cases of beer..
so far this is the most inexcusable and down right blatent deralection of responsability ive ever heard of,down here it is punishable by torture,you would be forced to listen to Barry Manalow medelies while watching THE English Patient,over and over till you were a slobering,gelatin like mass.
[Re: bonefish]
#1120931
11/28/11 07:24 PM
11/28/11 07:24 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
got a new one...
never ever break the first rule of engine building...mock up and measure everything twice before final machine work/balancing. or you might find out that pistons advertised as having a .050" dome and expected to stick up .030-.040 past the deck on an uncut block, actually stick up above the deck .083" and then find out that the piston manufacturer changed the piston 3 years ago, but never changed the online description/specs, etc.
DON'T ASK ME HOW I KNOW!
**Photobucket sucks**
[Re: TheBlackCar]
#1120933
11/30/11 09:15 AM
11/30/11 09:15 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
When taking your 125# dog to the track for the weekend with you, and sharing sleeping quarters (inside the trailer), DO NOT let the neighbor feed the dog left over chili.....Don't ask me how I know
DUUUDE!!!!!
[Re: RodStRace]
#1120934
11/30/11 01:35 PM
11/30/11 01:35 PM
Posts: 289 Flower Mound, TX, US
75dartcustom
When you grab that rear axle on wheels to roll it across the lot, do not grab the pinion snubber to hold up the center section. DAMHIK!
I won't ask, because I learned that one a couple of years ago. OUCH.
[Re: 75dartcustom]
#1120935
11/30/11 01:49 PM
11/30/11 01:49 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
When you start to prime the oil pump on a freshly rebuilt motor, be sure the oil filter is installed. Makes a HUGE mess. DAMHIK!
I'm embarrassed to admit I have done this twice, about 15 years apart.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
[Re: fasteddie]
#1120936
11/30/11 02:22 PM
11/30/11 02:22 PM
Posts: 1,377 Ohio
Todd
Ohio
Prime the engine and not have the one oil plug in the where the sender goes. It will shoot oil like a super soaker. DAMHIK!!!
